vtech problem!!!!
If you're talking about your vtech phone, I don't think that's related to your speedometer at all.
But your vtec isn't supposed to engage without a signal from the vehicle speed sensor. If your VSS is bad, your speedometer won't work AND your vtec won't engage.
i think its mad at you cause you spelled it wrong
plus vtec has nothin to do with speedo or tach, its all in the engine, you should hear a crossover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 »</TD></TR><TR><TD CLASS="quote">I tried searching but came up with nothing. I just need to know will the vtech work if my speedometer isnt working? i have a p72 ecu</TD></TR></TABLE>
There is your problem, honda motors must have give you a vtech motor instead of vtec motor. You should call them about that.
I'm sure a vtec rep could help you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z »</TD></TR><TR><TD CLASS="quote">You dont need to search...itll work regardless of your speedo.</TD></TR></TABLE>
civicseth
16
May 18, 2005 08:51 PM
