Suspension Problems. . .
Old Mar 4, 2005 | 12:50 PM
CircuitFG's Avatar
Default Suspension Problems. . .
This problem I've been having somewhat, but seems to have increase since installing the Full-Race traction bars. . . The problem is that when I take off from a stop, I have a lot of suspension movement. . .I actually hear a clunking sound and it makes the same sound through 3rd gear UNLESS i'm like slipping the gears in PERFECTLY. .. and when I mean perfectly, I mean like a sissy. . . I have to really baby it in to gear in order for it to not make a sound. When my brother was observing from the outside of the car, he said that he can physically see the wheel move like in a back and forth movement when I'm starting from a stop. . . Before I heard that, I thought it might be the motor mounts so i replaced all questionable mounts with new ones and got the ES Inserts and the problem never went away. . . I'm wondering if you think its the suspension bushings or the ball joints??? I'm planning on getting both done anyways, i just want to know to be pretty sure that It'll solve my problem. . .Driving my car is becoming more of a pain than a pleasure since it has been doing this. . .. I think its the bushings but I'm not sure. . The reason i think that is because it kinda seems like it would makes sense. Since the radius rods are now a solid piece instead of a rubber bushing at the end, it would put more pressure on the bushings that i have on there now. Which as of now are about 15 years old with over 200000 miles on them. . . Seems like it would be able to do some damage on old bushings. Any insite would be GREAT. . .thanks guys. .
Old Mar 4, 2005 | 04:32 PM
CircuitFG's Avatar
Default Re: Suspension Problems. . . (CircuitDA9)
nobody??? ttt
Old Mar 4, 2005 | 05:21 PM
Slain's Avatar
get your car on a lift and take a good look your suspension parts...give the wheels a wiggle .... my
issue turned out to be a bad upper ball joint
Old Mar 4, 2005 | 06:20 PM
NatrulyAspirated's Avatar
my camber kit made a clunking noise in the front... had to stick some washers in there to stop it from moving around. but yea lifting the car and moving stuff around helps
Octanum
Feb 28, 2012 12:14 PM
qazaq
Nov 13, 2009 04:49 AM
thehatchninja
Apr 17, 2005 08:45 PM
BrokeLude
Jul 27, 2004 07:50 AM
UnionCity LS
Jul 27, 2003 08:54 PM
