B16A B16A2
Old Mar 3, 2005 | 12:03 PM
Methane2k2's Avatar
Default B16A B16A2
is there any difference in horsepower/torque between the JDM B16 and the Si's B16A2???
Old Mar 3, 2005 | 01:29 PM
3.504's Avatar
Default Re: B16A B16A2 (Db2_iNtEgRa)
no difference in horsepower. probably no difference in torque. they are the same compression and maybe a slightly different cam, i'm not really sure on the cam.
jdm b16a from an sir2 (the eg6 motor) does have higher compression (10.4 compared to 10.2) and is rated at 170 horse but i'm not sure of the torque. before i was refering to the sir1/xsi motor (obd0) which is rated at 160
Old Mar 3, 2005 | 01:43 PM
98lsskunk's Avatar
Default Re: B16A B16A2 (3.504)
i think the 1rst gen. makes 160hp and the 2nd 170hp when in vtec, but maybe im thinking of the b16A3 makes 170
Old Mar 3, 2005 | 02:33 PM
3.504's Avatar
Default Re: B16A B16A2 (98lsskunk)
b16a3 is the del sol vtec motor. it makes 160. all usdm b16's make 160. the sir2 or "second gen" b16 (basically all jdm obd1 b16's) are rated at 170 and all pre-obd jdm b16's are 160
Old Mar 3, 2005 | 06:52 PM
quik89's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">b16a3 is the del sol vtec motor. it makes 160. all usdm b16's make 160. the sir2 or "second gen" b16 (basically all jdm obd1 b16's) are rated at 170 and all pre-obd jdm b16's are 160</TD></TR></TABLE>
and i think the cams are a lil more aggressive in the b16a2, vtec hits harder and is louder...
Old Mar 3, 2005 | 07:47 PM
Kendall's Avatar
Default Re: B16A B16A2 (Chris red99civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris red99civicsi &raquo;</TD></TR><TR><TD CLASS="quote">how much hp does the b16 in the 99 civic si have</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3.504 &raquo;</TD></TR><TR><TD CLASS="quote">all usdm b16's make 160.</TD></TR></TABLE>
Read, it's good for you.
Old Mar 3, 2005 | 08:44 PM
quik89's Avatar
Default Re: B16A B16A2 (Kendall)
and yes, that is the b16a2
Old Mar 4, 2005 | 12:36 PM
Methane2k2's Avatar
kool...i knew there wasnt a difference in HP and TRQ.....just making sure.....THe B17A has also 160 HP but it has a little more torque.....right?
Old Mar 4, 2005 | 03:55 PM
quik89's Avatar
i know it has the same horsepower, it might have like 112 ft lbs of torque, but i'm not sure on that
Old Mar 4, 2005 | 04:05 PM
Methane2k2's Avatar
this website seems to be right but not sure
http://www.supercars.net/garag....html
Old Mar 4, 2005 | 08:48 PM
riceball777's Avatar
there are 2 types of b16's not including the ctr (b16b)
There is the first gen kdm b16a which has 160hp and 111 tq just like all the usda b16's (b16a, b16a2, a3)
and theres the jdm second gen b16a which reads b16a just like the first gen
this one has 170hp, higher compression better im
the only differance between the usdm b16's and the first gen jdm b16 is that the jdm first gen b16 has really small LMA which suk.
all jdm bseris vtec motors also has a oil cooler
Old Mar 5, 2005 | 01:17 AM
Slain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Db2_iNtEgRa &raquo;</TD></TR><TR><TD CLASS="quote">kool...i knew there wasnt a difference in HP and TRQ.....just making sure.....THe B17A has also 160 HP but it has a little more torque.....right?</TD></TR></TABLE>
160 hp and 117lbs tq with measly low compression wish they came stock with bumped up compression oh well &lt;shrugs&gt;
Old Mar 5, 2005 | 09:10 AM
jdmef9gsr's Avatar
when u change from ob0 to ob1 u gain about 10 hp due to the fact that the ecu is dumping more fuel to the engine
Old Mar 5, 2005 | 10:58 AM
Methane2k2's Avatar
Default Re: B16A B16A2 (Slain)
How would u raise the compression on the B17???
Old Mar 5, 2005 | 11:37 AM
Slain's Avatar
Changing the pistons would be the sure way to get the compression you want. many people go with p30 pistons ...good way to bump the compression yet its still at a safe number...
JJGL-EF90
10
Feb 7, 2010 06:16 PM
-JSpecEk*9-
11
Jul 23, 2005 10:56 AM
phatboy
Apr 8, 2004 05:54 AM
Wafler
Feb 23, 2004 11:27 PM
loclowd
Jul 15, 2002 05:42 PM
