LS VTEC Problem
Old Mar 3, 2005 | 07:13 PM
fullracelsvtec's Avatar
Default LS VTEC Problem
I have a 93 Integra with an LS Vtec motor. The car runs great at first then when warmed up and driven for about ten miles and in second and third gear when you punch it around 3000 rpms it starts bogging down and does that until you hit about 5000 rpms. Does anyone have any idea what it might be? I have tried to search the other posts, but I have not found anything.
Old Mar 3, 2005 | 07:21 PM
Kendall's Avatar
Any codes? Double check the cam timing and the dizzy, make sure the car has good gas in it, and give it a compression test.
Old Mar 3, 2005 | 07:22 PM
LSTEG96's Avatar
Default Re: LS VTEC Problem (fullracelsvtec)
what ecu? whats the whole list...could be anything, spark, fuel, anything. if its a gsr head then maybe it picks back up around 5k because of the secondaries?
Old Mar 3, 2005 | 07:24 PM
Kendall's Avatar
Default Re: LS VTEC Problem (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">whats the whole list...could be anything</TD></TR></TABLE>
Yes indeed.
I have a thought. If you can't start focusing on what is the problem, then start eliminating what's not the problem.
Old Mar 3, 2005 | 07:48 PM
I do not have the full list in front of me now. It does not have a check engine light on. The motor is a B18 bottom end with a B16 head I think. The bottom end has 11.5 to 1 forged pistons and rods. The ECU is out of GSR or SI not sure? Stock distrubutor, intake manifold, throttle body, all sensors stock. Put in new plugs and tested the wires and everything works. Just running header and exhaust. The motor use to have a vtec controller and did not bogg down as much. The motor runs great from 5000 to 9600.
Old Mar 3, 2005 | 08:16 PM
neogenesis2004's Avatar
if it doesnt have a vtec controller anymore is vtec still kicking in?? sounds like it might not be.
Old Mar 3, 2005 | 09:06 PM
98lsskunk's Avatar
sounds like a problem with your spark, double check the wires and plugs, it might also be the distributor
Old Mar 3, 2005 | 09:56 PM
Default Re: LS VTEC Problem (neogenesis2004)
now that i think about it, i sorta had the same problem on my prelude before. turned out to me that my rotor and cap were severly worn
Deezydara
Jun 18, 2015 01:03 PM
lsvtecna
Jul 23, 2006 10:55 PM
olddohc
Jan 18, 2006 07:35 PM
ITR.#1446
Nov 24, 2004 08:56 PM
