another axle problem
Old Mar 3, 2005 | 06:01 PM
LANEVOIX's Avatar
Default another axle problem
there is a thud noise on front passenger side. when i looked under the car...there is all kinds of grease all over the axle area. the noise started only when i was turning and now when i'm going straight...there are no shakes or anything...when i brake the noise is gone...the sound doesn't get loud or anything...it sounds about the same all the time...it's been about two weeks and i am going to change the axle.
my question is: is it the axle thats broken or is it something else.
i never changed an axle before so i would like to know if when you remove the axle...will tranny fluid leak out...friends told me that only a little bit will come out...
thanks-jdmdingdong
Old Mar 3, 2005 | 06:12 PM
LANEVOIX's Avatar
Default Re: another axle problem (jdmdingdong4u)
bump anyone
Old Mar 3, 2005 | 06:48 PM
quik89's Avatar
cv joint
Old Mar 3, 2005 | 08:15 PM
Carnage R1's Avatar
Default Re: another axle problem (quik89)
you got to much power!
Old Mar 3, 2005 | 09:27 PM
eK9aT10pSi's Avatar
id go to autozone and buy a lifetime warranty one, like 60$ + core
Old Mar 4, 2005 | 09:46 AM
92 blue teg's Avatar
i broke an axle two months ago. car will not move if u broke the passenger side . i found out the hard way after i bought a b16 trans. i dont need.
Old Mar 4, 2005 | 11:20 AM
cnydc2's Avatar
Default Re: another axle problem (heathb)
deffinatly sounds like your cv shaft is taking a poo. I'd hurry and get a new one from Advance or Autozone and get it fixed before it breaks and leaves you stranded.
steezychristian
Oct 2, 2011 05:25 PM
Osek206
Sep 18, 2005 06:53 PM
penney
Apr 16, 2004 06:58 PM
1 speedstar
Jul 18, 2003 03:58 PM
