Adjusting Kickdown Cable on Auto Integras
Old May 25, 2005 | 10:55 PM
WTB AUTO EK's Avatar
Default Adjusting Kickdown Cable on Auto Integras
Anyone know how to adjust the kickdown cable on automatic integras?
It shifts really hard, I dont think its the transmission that is damaged.
Old May 27, 2005 | 11:55 PM
Default Re: Adjusting Kickdown Cable on Auto Integras (SSImpala)
ideas?
Old May 28, 2005 | 09:24 AM
ALMXDUPINTEGRA's Avatar
???Kickdown cable
Old May 28, 2005 | 10:29 AM
suspendedHatch's Avatar
Default Re: (ALMXDUPINTEGRA)
It's the same method as adjusting the throttle cable.
Acura/Honda autos normally shift hard. It's how they're built, and its not a bad thing. Less slippage = less heat
If you adjust that cable, you're going to change your shift points. Tighten it, and you will go to higher RPM before shifting. It's pretty annoying to cruise at 3000RPM in third gear.
Old May 29, 2005 | 11:19 PM
Where is this cable located?
Old May 29, 2005 | 11:46 PM
IntegraCF21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALMXDUPINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">Where is this cable located?</TD></TR></TABLE>
Yeah, I would like to know as well.
Old May 30, 2005 | 01:46 PM
ttt
Old May 30, 2005 | 02:16 PM
Do you ever look at your engine, son? You see where your throttle cable goes to the spring on the throttle body? Then there's another cable going from there to your trans. You adjust it at the bracket on the throttle body.
Old May 31, 2005 | 06:55 AM
thanks for the help
Old May 31, 2005 | 07:39 AM
Yeah,
You unlock the two nuts, then move it to either side to adjust the kickdown cable. If you tighten it to much, it shifts harder.
Old May 31, 2005 | 11:57 AM
What do you mean by shift harder?
Old May 31, 2005 | 12:22 PM
TEXN3's Avatar
Default Re: (Teg6)
you can feel the shift a little more...most newer cars shift very smoothly and you can hardly notice it. some hondas, mainly with 4cyl motors, upshift with more abruptness. i've noticed that my DA shifts a little more harshly at lower rpms than at higher rpms. doesn't bother me at all.
Old May 31, 2005 | 01:01 PM
projectTeG's Avatar
hrmmm...my da didnt have this "kickdown" cable when it was a auto., the newer tegs have this?&gt;
Old May 31, 2005 | 02:23 PM
TEXN3's Avatar
Default Re: (projectTeG)
it should have, mine does.
Old May 31, 2005 | 03:04 PM
Could someone post a pic of the cable?
Old May 31, 2005 | 09:36 PM
Default Re: (Teg6)
Ill see if i can get your a picture of mine tommorow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg6 &raquo;</TD></TR><TR><TD CLASS="quote">Could someone post a pic of the cable?</TD></TR></TABLE>
Old Jun 1, 2005 | 06:48 PM
Default Re: (SSImpala)
Nevermind, I found it. At first I put it all the way over so it was really tight and turned on the car and it was super loud(my n1 exhaust) so then I tuned it about 6 different times to get it where I wanted it. The shift point is higher than before and it seems to accelerate more faster as well.
Old Jun 1, 2005 | 06:50 PM
Default Re: (Teg6)
By the way, will this damage the car in anyway because it seems to kind of make the engine work a little bit harder.
Old Jun 1, 2005 | 08:01 PM
Default Re: (Teg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg6 &raquo;</TD></TR><TR><TD CLASS="quote">By the way, will this damage the car in anyway because it seems to kind of make the engine work a little bit harder.</TD></TR></TABLE>
theres claims that it will damage your transmission but not your engine. if you mess up your tranny, just get a manual one and do a conversion
Old Jun 3, 2005 | 12:00 AM
I couldnt find it.
Old Jun 3, 2005 | 12:21 PM
projectTeG's Avatar
^^^^^^^^ thats the throtle cable, the only hondas i know of that have this type of cable to the tranny is the auto accord f22 motors
Old Jun 3, 2005 | 03:14 PM
SilverDc2's Avatar
i thought that cable was for the gas pedal adjustment....weird.
Old Jun 3, 2005 | 03:18 PM
projectTeG's Avatar
Default Re: (SilverDc2)
yea....the cable the others are talking about goes from the auto tranny to the tb,,,,lol, im still trying to find out how other integras have this and my car( when it was auto) didnt have this and had no space on the tranny for it
Old Jun 3, 2005 | 05:33 PM
Haha, guess I was messing with the wrong cable.
Old Jun 3, 2005 | 05:34 PM
Default Re: (Teg6)
For the people who did find it or think they did, could you please post a pic.
