abs sensor wire broken...
Old May 25, 2005 | 07:15 PM
maxogsr's Avatar
Default abs sensor wire broken...
1st...Is it possible to change only the abs wire without changing the sensor itself?
2nd question...If I purchase an abs sensor, wil it come with the wire? I have a code on my rear driver side but I think it happen when I changed the hub latetly...
Or I twist the wire too much, or the sensor got ****-up when I hit the disc with hammer to unjam the thing...
What do you guys think?
Old May 25, 2005 | 10:11 PM
1993sir05's Avatar
Default Re: abs sensor wire broken... (maxogsr)
if the wire isnt broken then you should just clean off the sensor.
Old May 26, 2005 | 01:53 AM
maxogsr's Avatar
Default Re: abs sensor wire broken... (1993sir05)
Any other advise? If I want to clean it, what should I use?
Old May 26, 2005 | 11:09 AM
1993sir05's Avatar
i would wipe it off with a clean rag, and then spray it lightly with brake cleaner. but thats just me i may get abused for saying this.
chazt
Honda CR-V & Element
Apr 16, 2013 01:04 PM
DoRoJo
Sep 26, 2012 12:56 PM
BAY_99DB8LUV
Mar 9, 2011 11:17 AM
b18ccivics
Jul 31, 2005 01:46 PM
sQwiReL bOi
Jun 10, 2004 06:56 AM
