Lowered problems
Old May 26, 2005 | 08:03 AM
quick_ls's Avatar
Default Problems lowering my car (control arms)
Ok, i see all these Integras that are low, tires tucking a little. Does your upper control arm not hit the strut tower?
I have ground control coil overs, with Tokico 5 way adjustable and Ingalls camber kit. I lowered it with the tires level with the fender and the upper control arm hits. Of course i raised it up
how do you do it?
*edit* i did a search and found some answers
Modified by quick_ls at 1:34 PM 5/26/2005
Old May 26, 2005 | 09:52 AM
E.J.'s Avatar
わたしは。。。
Default Re: Lowered problems (quick_ls)
Your control arms will hit because you are running a camber kit, the only way to go low without hitting is w/ your stock control arms
Old May 26, 2005 | 10:15 AM
mrmonk's Avatar
Default Re: Lowered problems (E.J.)
I'm loving the grammar usage of the title.
Old May 26, 2005 | 12:33 PM
quick_ls's Avatar
Default Re: Lowered problems (mrmonk)
haha its great grammar...
stock control arms.. eeekk that be some nasty negative camber
Old May 26, 2005 | 01:04 PM
FDSWintegra's Avatar
Mine is lowered 2.5F 2.0R and mine do not thump or hit. I am even running skunk2 adjustable control arms. That thumping could be a ball joint goin out. That is why i put the skunk2's on it cause mine were thumpin......
Old May 26, 2005 | 01:24 PM
quick_ls's Avatar
Default Re: Lowered problems (FDSWintegra)
I knwo what the thumping is.. just a way to stop it. I can see now how the ingalls kit moved the control arm out some.
mine is dropped more then 2.5 i think. i have 16s and you couldnt fit any fingers between my tire and fender.
I just saw in another post "slammed cars" and how extremely low people have been driving their cars around.
Old May 26, 2005 | 01:40 PM
E.J.'s Avatar
わたしは。。。
As far as some controls arms not hitting, sounds great, but all the control arms I've used in the past all had that problem (ingalls and skunk2). I have negative 3 degrees camber, but it's not daily driven
2.6lrex
Feb 11, 2012 04:55 AM
97elitehonda
Suspension & Brakes
May 7, 2007 10:06 AM
DeLiRiOu5
Oct 7, 2003 05:04 AM
patastinky
Jun 17, 2003 02:44 PM
