speaker conversion
Old May 25, 2005 | 08:02 PM
sickofitall1113's Avatar
Default speaker conversion
i am thinking about putting 2 6x9 speakers on the back deck and taking out the two 6.5's from the back because they rattle a lot. i am thinkning i can do this to make it sound a lot better with more bass. have any of you done this? what do you think of it and if it would work well.
Old May 25, 2005 | 08:08 PM
mr.beeks's Avatar
Default Re: speaker conversion (sickofitall1113)
6X9 not worth it keep it stock
if you visit crutchfield they have plastic converters to make 6x9 with out
modifying anything....
Old May 26, 2005 | 04:10 AM
Default Re: speaker conversion (mr.beeks)
anyone done this?
Old May 26, 2005 | 04:56 AM
type gsr's Avatar
I cut out holes in the hatch cover, and dropped two 6X9s in boxes in the holes i cut out. It doesn't look bad at all
Old May 26, 2005 | 09:41 AM
TunerN00b's Avatar
I don't see how you'll get much, if any, more bass from a 6x9 than the stock 6.5, especially if you're using the stock headunit. Leve the rears stock, get some better front speakers, and if you want bass, get a sub.
Old May 26, 2005 | 11:48 AM
Default Re: speaker conversion (TunerN00b)
well i have an alpine deck, prob the best brand you can buy with the bass engine in it. im very impressed with it. i was trying to stay away from subs as i am doing weight reduction things now and that would be counterproductive to get a big sub box in the hatch. my big quib with the stock rear speakers now is that they rattle a lot with that stupid plastic peice over it.
Old May 26, 2005 | 01:02 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
your problem seems to be you want what you can't have.
6.5 to 6x9 is not what I would say do. If anything get BETTER speakers and add a SMALL 4 channel amp to them. Minimal weight, better response, and maximum output. The best of both worlds.
Asking for much bass out of a 6.5 or 6x9 is gonna cause you to buy a lot of speakers man, you'll be blowing them left and right. Good luck .
Old May 26, 2005 | 01:11 PM
patmcd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 &raquo;</TD></TR><TR><TD CLASS="quote"> my big quib with the stock rear speakers now is that they rattle a lot with that stupid plastic peice over it.</TD></TR></TABLE>
Sounds like you need to take the cover off and see what is rattling. The only time I've seen the rear 6.5's rattle is when they are installed incorrectly.
Old May 26, 2005 | 01:14 PM
Default Re: speaker conversion (patmcd)
the plastic trim peice is rattling against itself. not the speaker itself.
Old May 26, 2005 | 01:17 PM
gwsexton425's Avatar
You should look for a new plastic piece then.
Old May 26, 2005 | 01:27 PM
Default Re: speaker conversion (gwsexton425)
haha theres nothing wrong with the plastic peices. when there is a lot of bass and there is plastic on top of plastic its going to rattle. i guess i could put some foam in there or something.
JDM_SOHC
Audio / Security / Video
77
Sep 28, 2010 06:49 PM
dungsta
Jul 27, 2004 06:19 AM
VTECPWR
May 16, 2002 09:49 AM
RuskeR
Dec 28, 2001 01:36 PM
GoLowDrew
May 15, 2001 07:01 PM
