Integra Upper control arm.
Old May 31, 2005 | 08:51 AM
EdoMoto's Avatar
Default Integra Upper control arm.
I need the joint thats on the outside of the uppercontrol arm anyone have a part number for it? Does it come seperate from the whole arm?
http://www.acuraoemparts.com/d...ch=no
THANX Edo
Old May 31, 2005 | 09:25 AM
tegmaniac's Avatar
Default Re: Integra Upper control arm. (ITAIntegraLS)
I believe from acura you have to get the arm and ball joint together
Old May 31, 2005 | 11:37 AM
Honda Hick's Avatar
Default Re: Integra Upper control arm. (tegmaniac)
You talkin about #9, #20, and the part around it? If so you can find plenty of them used because people put in Ingalls camber kits that replace those parts.
Old May 31, 2005 | 01:19 PM
IN VTEC's Avatar
I got a set you can have - just the arm and balljoint (no fasteners, shock tower mounting brackets, or bushings). You just need to replace the balljoint boot since I gashed them using a fork to split the balljoint off the knuckle.
If you don't want to replace the boots, I can do it for you since I might have a spare pair of upper balljoint boots in the spare parts box. You'd have to pay me for a replacement set tho since I might have need for them later on.
PM me if you want them.
whyS0serious
Suspension & Brakes
Apr 17, 2018 12:45 PM
Hunters teg12
Suspension & Brakes
Aug 3, 2013 12:39 PM
19Accord97
Apr 27, 2009 07:10 PM
IK_Noodle
Jul 15, 2007 12:04 PM
EdoMoto
May 31, 2005 11:09 AM
