fOG LIGHT QUESTION?
Old Jun 1, 2005 | 11:41 AM
AznMTboy's Avatar
Default fOG LIGHT QUESTION?
I got a set of foglight and i tested it by using the car battery and it doesnt light up.
and I heard dat battery power doesnt work with the foglight, but some how u need to do some different wiring to different power source in the car beside the battery.
Any one have an opinion to share because I would like to know how to wire the foglight to make it work.
Old Jun 1, 2005 | 12:05 PM
PLAGUED_DB7's Avatar
Default Re: fOG LIGHT QUESTION? (AznMTboy)
its cause you didnt wire it to the switch to turn it on.
no really. I think that it goes into the fuse box underneath the dash and that
coverts it to like 12v or some **** like that...GL
Old Jun 1, 2005 | 12:21 PM
TEXN3's Avatar
Default Re: fOG LIGHT QUESTION? (PLAGUEDDB7)
you need to wire the fogs to a switch. then you can wire the power to the battery, using an inline fuse, also wire a ground. that's all i did. even have a nice little switch that is black and has a little light...about as factory as i could get.
inline fuse holder:
http://www.radioshack.com/prod...-1238
switch(similiar to mine):
http://www.radioshack.com/prod...2D730
don't forget the clamps/connectors and the other little things.
good luck.
Old Jun 2, 2005 | 01:17 AM
DC4RS Integra's Avatar
normally you'll have to wire the main power, switch power, and relay power to the batterie and there should be 2 or 3 ground, and you have to connect the switch to work the fog light.
Old Jun 2, 2005 | 12:10 PM
AznMTboy's Avatar
Default Re: fOG LIGHT QUESTION? (TEXNTEG)
thanks you everyone.
hardrock2401
Oct 13, 2013 06:50 PM
91-lsvtecsi
Mar 15, 2012 04:14 PM
thatasiankidtony
Audio / Security / Video
Nov 7, 2006 02:18 PM
EliteCivicX
Apr 10, 2005 06:07 PM
Halo
May 11, 2003 06:44 PM
