what does ths check engine code mean?
Old Jun 1, 2005 | 09:57 AM
sickofitall1113's Avatar
Default what does ths check engine code mean?
P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
i found that out at autozone, they said it was a bad gas cap and i bought a new one...could it be something else?
Old Jun 1, 2005 | 09:59 AM
HoUTX98GSR's Avatar
Default Re: what does ths check engine code mean? (sickofitall1113)
sometimes they say its because you didnt tighten your gas cap enough or you have a bad gas cap.. try keeping it tight and reset the ecu
Old Jun 1, 2005 | 10:05 AM
Default Re: what does ths check engine code mean? (HoUTX98GSR)
how do you reset the ecu? just dissconnect the battery?
Old Jun 2, 2005 | 07:35 AM
nope it wasn't the gas cap because i reset the ecu by dissconnecting the battery and reconnecting it. after about 50 miles it came back on. does this code mean anything else besides a loose or bad gas cap?
Old Jun 2, 2005 | 08:30 AM
anyone?
Old Jun 2, 2005 | 09:53 AM
bump
Old Jun 2, 2005 | 10:32 AM
CNSK's Avatar
your evap purge is probaly bad.....theres 2 hoses that connect to your evap purge ....one hose goes the manifold and the other to the canister...and then theres a plug harness to the evap purge...check and see if anything is loose....
Old Jun 2, 2005 | 10:39 AM
Default Re: what does ths check engine code mean? (CNSK)
ok first...what is an evap purge and canister. and where is it and i will check it.
Modified by sickofitall1113 at 11:49 AM 6/2/2005
Old Jun 2, 2005 | 08:14 PM
c'mon someone knows...
Old Jun 4, 2005 | 07:16 PM
someone please help
Old Jun 4, 2005 | 07:56 PM
dcb16's Avatar
i think the evap can is aka charcol canister. if it is, its a black canister that is on the passenger side corner of the engine bay. close to the battery. its a pretty good size, maybe about half of a gallon jug.
Old Jun 4, 2005 | 07:58 PM
Default Re: what does ths check engine code mean? (dcb16)
thanks i will go check that
Old Jun 5, 2005 | 06:51 AM
all hoses are good to that thing...if i even found the right thing...anyone have this problem before? someone help
Old Jun 5, 2005 | 09:28 AM
Yambor's Avatar
Just for future reference, and this might help you out:
Old Jun 5, 2005 | 06:42 PM
Default Re: what does ths check engine code mean? (JH4DC4-2GSR)
cant see the link
Old Jun 5, 2005 | 06:59 PM
cleantegra's Avatar
buy another gas cap from the dealership sometimes autozone crap dont cut it
Old Jun 8, 2005 | 08:50 PM
dcb16's Avatar
Default Re: what does ths check engine code mean? (cleantegra)
make sure you tightend the gas cap all the way down, then wait a couple days, the cel stays stored for a few days even after the problem is fixed.
Old Jun 9, 2005 | 07:04 AM
97tegGS's Avatar
Engine Control Module (ECM) Reset Procedure
Turn the ignition switch OFF. Remove the BACK UP (7.5 A) fuse from the under-hood fuse/relay box for 10 seconds.
Old Jun 12, 2005 | 08:09 PM
dcb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 &raquo;</TD></TR><TR><TD CLASS="quote">P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
i found that out at autozone, they said it was a bad gas cap and i bought a new one...could it be something else?</TD></TR></TABLE>
yes, it could be something else. but dont just go buying parts and throwing them at the car. it could be the evap canister leaking, shorted circuit, unplugged vac line, etc. my guess is an unplugged vac line. should be one going to the manifold from the canister.
Old Jul 8, 2005 | 08:02 AM
karwan's Avatar
Default how do you reset the ecu? just dissconnect the battery?
Old Jul 9, 2005 | 03:19 PM
Ultra Jurassic's Avatar
Default Re: (97tegGS)
to be exact, it's the 7.5 fuse for the radio.
slimsol
Jan 5, 2011 06:11 AM
xtn5021
Sep 22, 2009 06:21 PM
kloscivicsi
Honda Civic (2006 - 2015)
May 8, 2007 05:47 AM
londonsupra
Jul 7, 2006 05:30 PM
slowj
Jan 18, 2004 11:18 PM
