icu
Old May 28, 2005 | 01:01 PM
crxchris's Avatar
Default icu
ok so apparently i think my icu is going bad as my rear defrost intermittint(sp?) wipers and cruise all dont work can anyone tell me how i can test and\or replace it did search and didnt see anything on testing or how to any help would be greatly appreciatd thanks
Old May 28, 2005 | 01:04 PM
Lord Helmet's Avatar
Default Re: icu (crxchris)
WTF is a icu?
Old May 28, 2005 | 01:06 PM
kingteghelm's Avatar
I have never heard of an icu, is there a such thing?
Old May 28, 2005 | 01:07 PM
HARI.'s Avatar
Default Re: icu (Lord Helmet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Helmet &raquo;</TD></TR><TR><TD CLASS="quote">WTF is a icu?</TD></TR></TABLE>
integrated control unit. this is known to go bad on the DA's. symptoms are rear defroster stops working, and wiper relay will also stop working.
this is located behind the fuse box under the dash on your left side. you have to take the (2)12mm bolts that's holding the fusebox out to get to it. unplug the harness and pry it off carefully.
this is what it looks like
Modified by DA9-hari at 6:24 PM 5/28/2005
Old May 30, 2005 | 12:48 PM
crxchris's Avatar
Default Re: icu (DA9-hari)
thank you for your assistance is there a way to check it to see if that is the problem, or should i just replace it
Old May 30, 2005 | 01:09 PM
mr.beeks's Avatar
I got one of those
if you need it show me the $$$$
Old May 30, 2005 | 01:19 PM
ALMXDUPINTEGRA's Avatar
Did you have to use WTF?
Old May 30, 2005 | 01:54 PM
crxchris's Avatar
also would this cause a "phantom" beeping it happens randomly and is very annoying
Old May 30, 2005 | 04:30 PM
HARI.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxchris &raquo;</TD></TR><TR><TD CLASS="quote">thank you for your assistance is there a way to check it to see if that is the problem, or should i just replace it </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxchris &raquo;</TD></TR><TR><TD CLASS="quote">also would this cause a "phantom" beeping it happens randomly and is very annoying</TD></TR></TABLE>
there is no way to check to see if it's bad. you already have the symptoms. just replace it
and yes you will get that annoying beep from the seatbelts when it is bad. trust me it happened to me and i replaced it and it was gone.
Old May 30, 2005 | 06:24 PM
Default Re: icu (ALMXDUPINTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALMXDUPINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">
Grow a thicker skin
"In life sometimes you gotta say WTF"
Old May 30, 2005 | 09:03 PM
EV1L SI's Avatar
SCAM ARTIST
The seatbelt beeping can be stopped, but it will also disable your auto belts. Just make sure they are already in position to keep before you do this. Remove the kick panel on the passenger side and you will find a greyish metal box with a green plug going into it. Unplug it, beeping stops.
Old Jun 7, 2005 | 02:47 PM
crxchris's Avatar
Default Re: icu (EV1L SI)
got new part today however it has 7A next to the word japan does this make a differance? thanks
Old Jun 8, 2005 | 02:32 PM
crxchris's Avatar
bump
Old Jun 10, 2005 | 02:22 PM
crxchris's Avatar
ok so got new one installed rear defrost and wipers work but cruise still does not any ideas? thanks
Old Jun 11, 2005 | 12:12 PM
crxchris's Avatar
bump
JDMister_EF9
11
Sep 5, 2006 01:21 PM
Si_chRis
Aug 7, 2006 05:22 PM
janz3n
Aug 4, 2006 05:32 PM
sleeperteg
Acura TL, RL & ZDX
Feb 5, 2006 11:11 AM
