window problem-gsr
Old May 30, 2005 | 02:09 PM
mugenspoongsr's Avatar
Default window problem-gsr
I have a 94 integra gsr and i have a window problem. my pasanger window when i try to put it down it goes really slow until its down about 5 inches then it shoots down like normal. lately its been stopping after like the 5 inches then u have to keep clicking the button then it finally goes down. when i try and put it up there are no problems. i took off the door panel today to see if anyhting was in the way and there isnt it looks clean. what do you think the problem is?
Old May 30, 2005 | 02:13 PM
sickofitall1113's Avatar
Default Re: window problem-gsr (mugenspoongsr)
take the panel of again and see if something is lodged in the track the window goes down on. does the window go up alright? could be your window motor going bye bye.
Old May 30, 2005 | 02:18 PM
Yambor's Avatar
Default Re: window problem-gsr (sickofitall1113)
Does your window rattle too? Take your door panel off and see if the molding on the track has come out.
And for the travel problem, lubricate the trackin and motor with air tool oil.. Seems to work very well.
Old May 30, 2005 | 02:41 PM
FormulaGSR's Avatar
Default Re: window problem-gsr (JH4DC4-2GSR)
lube the track. you should do this regularly.
Old May 30, 2005 | 02:44 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 &raquo;</TD></TR><TR><TD CLASS="quote">take the panel of again and see if something is lodged in the track the window goes down on. does the window go up alright? could be your window motor going bye bye.</TD></TR></TABLE>
its not the motor; if it was it would go down just fine, but take longer going up. i had to replace a motor in my old accorn, the passenger motor in my teg is on its way out; while i replace that i might as well do the switch. the passenger switch will roll it down but not up, which is annoying.
Old May 30, 2005 | 03:07 PM
Default Re: window problem-gsr (benb18a)
yea i had to replace motors in a couple cars. i see your point... but it was just an idea.
Old May 30, 2005 | 05:59 PM
FormulaGSR's Avatar
i'ld try lubing the track before i spent any money. I did that on my wifes civic and solved all its problems. I took the door panel off and lubed the regulator too. Didnt cost **** and its good as new.
Old May 30, 2005 | 07:23 PM
Default Re: window problem-gsr (FormulaGSR)
thanks a lot ill try that tomorrow.
8YourV8
Dec 13, 2010 10:09 AM
VSG
Mar 7, 2008 10:46 AM
deerman2701
Nov 27, 2007 05:59 AM
i-want-a-crx
Oct 13, 2007 08:41 AM
C2daIzZle
16
Sep 9, 2005 05:06 AM
