proper position for intake
Old Jun 1, 2005 | 09:41 AM
sickofitall1113's Avatar
Default proper position for intake
i got a k&n intake from ebay about 3 months ago. the pipe barely fit and the filter barely even got in there. it is touching the coolant resvoir. should it be that close? basically bottom line....should i buy a new intake that fits better...
Old Jun 1, 2005 | 10:29 AM
Default Re: proper position for intake (sickofitall1113)
c'mon someone humor me and answer this dumb question.
Old Jun 1, 2005 | 10:32 AM
.water's Avatar
you get what you pay for suckaaa..lol jp
if you want help put some more detail. what car?
possible to take a pic?? yes ive seen filter close to coolant resvoir. but not touching. try to push filter into pipe more
Old Jun 1, 2005 | 10:34 AM
Default Re: proper position for intake (Chris DC2)
99 LS. its probably ok but it just seems like the filter shouldn't be so close to the anit-freeze resevoir. i would post a pic but i dont know how to.
Old Jun 1, 2005 | 10:35 AM
be.twenty's Avatar
is it cold air intake or short?
Old Jun 1, 2005 | 10:39 AM
Default Re: (shogun-dc2)
cold air intake
Old Jun 1, 2005 | 10:40 AM
be.twenty's Avatar
is it touching or actually pushing the resivoir?
Old Jun 1, 2005 | 10:42 AM
its just touching it . theres prob like 1/2 mm between it...so thats almost nothing so yea it touches...but does not push it.
Old Jun 1, 2005 | 10:46 AM
be.twenty's Avatar
i say leave it then...
OH, btw.. is the CAI bolted down so it doesn't move?
Old Jun 1, 2005 | 10:49 AM
no its not bolted down...but its so tight in there it has virtually no movement anyway. it didnt come with anything to stabilize it really.
Old Jun 1, 2005 | 10:51 AM
be.twenty's Avatar
Default Re: (sickofitall1113)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickofitall1113 &raquo;</TD></TR><TR><TD CLASS="quote">no its not bolted down...but its so tight in there it has virtually no movement anyway. it didnt come with anything to stabilize it really.</TD></TR></TABLE>
THere's a spot to throw in a bolt from where you took your stock airbox out. See if you can drop a 1" bolt in there and then use a zip tie to secure the CAI to the bolt so it doesn't hit your coolant or AC lines.
Old Jun 1, 2005 | 10:57 AM
alright i'll try that...thanks a lot.
kelviiv
Sep 19, 2008 09:33 AM
mitcho
13
Jul 12, 2007 05:39 PM
Manolo
55
Jul 13, 2005 07:26 AM
Nihilus
11
Mar 10, 2005 04:31 PM
ef_you
10
Jan 11, 2005 12:24 PM
