o2 sensor??!?
Old Jul 21, 2005 | 08:21 AM
GoCarInteg's Avatar
Default o2 sensor??!?
will a bad o2 sensor cause a high nox level on smog? i failed twice with a b20. i got a 3500 nox level and 700 is max. also, my check engine light comes on every once in a while, could that be cause by an o2? i know that a bad o2 will turn it on but only every once in a while?!?!
Old Jul 21, 2005 | 09:33 AM
knomexx's Avatar
Default Re: o2 sensor??!? (GoCarInteg)
a bad o2 sencor will not cause excessive nox levels
Old Jul 21, 2005 | 10:03 AM
LSvtec03's Avatar
why don't you check the code and find out?
Old Jul 21, 2005 | 10:14 AM
HmgLauj69's Avatar
check the forced induction section, there was this guy who only changed the o2 after he failed. hc, co, and nox went down
Old Jul 23, 2005 | 08:25 PM
GoCarInteg's Avatar
Default Re: o2 sensor??!? (HmgLauj69)
checked my codes. bad o2. and fuel supply system (injectors and maybe filter). i changed my filter like 30k ago. think it's still good?
Old Jul 23, 2005 | 08:44 PM
TEiK's Avatar
check your catalic convertor. it might be bad
Old Jul 23, 2005 | 08:59 PM
Backk InTheDA's Avatar
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg &raquo;</TD></TR><TR><TD CLASS="quote">i changed my filter like 30k ago. think it's still good?</TD></TR></TABLE>
I think its supposed to be changed every 60k miles. So that should be fine.
Old Jul 24, 2005 | 06:17 PM
GoCarInteg's Avatar
Default Re: o2 sensor??!? (TEiK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEiK &raquo;</TD></TR><TR><TD CLASS="quote">check your catalic convertor. it might be bad</TD></TR></TABLE>
i thought the same thing. i just replaced the cat and it only dropped the nox about 200. oh well.. hollowed out my old one
Old Jul 29, 2005 | 12:44 PM
TEiK's Avatar
Have you check your timimg (TDC mark)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg &raquo;</TD></TR><TR><TD CLASS="quote">checked my codes. bad o2.
you might have a lazy o2, replace it.
Old Jul 30, 2005 | 05:31 PM
GoCarInteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEiK &raquo;</TD></TR><TR><TD CLASS="quote">Have you check your timimg (TDC mark)?
you might have a lazy o2, replace it.</TD></TR></TABLE>
i was on 16. but i replaced my o2. **** was white. $35 at the junkyard. passed with flying colors... thanks everybody
Old Jul 30, 2005 | 05:42 PM
P95's Avatar
P95
good that its fixed. was the car still on OBD1 or was it 2 after the swap?
on OBD2 cars, if you have a check engine light on you always fail emissions, regardless of what it is.
Old Aug 1, 2005 | 12:26 AM
GoCarInteg's Avatar
Default Re: o2 sensor??!? (P95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P95 &raquo;</TD></TR><TR><TD CLASS="quote">good that its fixed. was the car still on OBD1 or was it 2 after the swap?
on OBD2 cars, if you have a check engine light on you always fail emissions, regardless of what it is.</TD></TR></TABLE>
still kept it OBD1. The check engine light kept coming on at random. The wierd thing is that i brought my **** to honda so they could read the light and nothing showed up on their system. oh well.
perpetualburn
May 16, 2007 06:49 PM
silverboost
Aug 23, 2005 09:11 AM
thrty8street
Jul 15, 2004 08:00 PM
allmotorsi04
Dec 6, 2003 03:08 PM
CEC76
Feb 25, 2002 10:20 AM
