Having Problems with my DA
Old Jul 20, 2005 | 01:10 AM
eg6-equipED's Avatar
Default Having Problems with my DA
alright well, my car started this about three weeks ago. One day it completely shut off on me, so i got it towed home, i checked everything, i found out i wasnt getting any spark, so i changed the distributor, then it turned on and it ran good for about 2 weeks, then coming out of the freeway, it turned off on me again, it was night time so i got it towed again, then the next morning, checked it out, and it wouldnt even crank, so i thought it was the starter...so i just changed that, it worked fine for about a a few days, then today i went outside to leave, got in the car, and it wouldnt start. NOW WHAT IS IT!??!?! i cant figure it out, what could it be?! can anyone please help me?!?!?!!?!?!?
Old Jul 20, 2005 | 02:15 AM
JUN-DA6's Avatar
Please check the following:
1. check the voltage of your battery.
2. check the efficiency of your alternator.
3. check or replace(<- recommended) main relay (located leftside above fuse box)
4. check ecu function
5. check fuel pump function
Good luck to you!
Old Jul 20, 2005 | 04:45 AM
DA-nteg's Avatar
Default Re: (JUN-DA6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN-DA6 &raquo;</TD></TR><TR><TD CLASS="quote">Please check the following:
3. check or replace(&lt;- recommended) main relay (located leftside above fuse box)
Good luck to you!</TD></TR></TABLE>
My thought as well
Old Jul 20, 2005 | 04:51 AM
Default Re: (DA-nteg)
THANKS A LOT GUYS!!! IM GONNA CHECK THAT OUT FIRST THING TOMORROW MORNING. ILL LET YOU GUYS KNOW WHAT IS GOING ON, AGAIN THANKS!
88hondaspeed
13
Jun 9, 2011 09:17 AM
Black 92
Feb 17, 2008 11:25 PM
antiricer
13
Jan 20, 2007 02:52 PM
hurraquio
Feb 4, 2006 07:34 PM
CTRwannaB
13
Mar 29, 2004 08:11 AM
