ADVICE NEEDED
Old Jul 21, 2005 | 08:40 AM
tik_tok's Avatar
Default ADVICE NEEDED
need some advice,
gotta b18 block, ls, i wana go vtec, lets say i throw on a b16 00 si head, ported and polished what kinda power am i looking, at, already ahve basic bolt ons, so what else would be needed to boost, im think balnced bottom end, low comp pistons, and some bullshit cams for now, but basicall i REALLY need to know will that b16.b18 combo work????
Old Jul 21, 2005 | 08:56 AM
AllMotorDan's Avatar
im sure it will...has been done many times by now. I'd search if i were you cause the ls/vtec isn't anything rare.
Old Jul 21, 2005 | 08:57 AM
mrdeadman's Avatar
They let me pick
Default Re: ADVICE NEEDED (tik_tok)
it would be easier and cheaper to just buy a used gsr engine, if you want vtec that way nothing gets screwed up when youre trying to make an ls a vtec. you cant just throw on a head and call it vtec, there is a bunch of crap you have to do. it takes experience to pull that off. also why would you want to have a vtec and a turbo? you might as well just put in some cams with an aggressive lobe, kind of like the vtec lobe, then it would be almost like running vtec all the time. turbo is the way to go, not vtec and then turbo, turbo will make way more power. ls engines also already have low enough compression so you wont blow the head off running about 12psi of boost you shouldn't lower the compression any more. also dont buy crappy cams, just save up and buy good stuff. you really need to know what youre doing before you try to pull any of this off by yourself, so start reading up and know what you want and how to do it then do it. we cant hold your hand along the way.
Old Jul 21, 2005 | 09:25 AM
Backk InTheDA's Avatar
I hate everything
Default Re: (SpoonSirG)
THe b16 head w/ b18 bottom will work fine. There both B series
Old Jul 21, 2005 | 10:08 AM
LSvtec03's Avatar
Default Re: ADVICE NEEDED (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">it would be easier and cheaper to just buy a used gsr engine, if you want vtec that way nothing gets screwed up when youre trying to make an ls a vtec. you cant just throw on a head and call it vtec, there is a bunch of crap you have to do. it takes experience to pull that off. also why would you want to have a vtec and a turbo? you might as well just put in some cams with an aggressive lobe, kind of like the vtec lobe, then it would be almost like running vtec all the time. turbo is the way to go, not vtec and then turbo, turbo will make way more power. ls engines also already have low enough compression so you wont blow the head off running about 12psi of boost you shouldn't lower the compression any more. also dont buy crappy cams, just save up and buy good stuff. you really need to know what youre doing before you try to pull any of this off by yourself, so start reading up and know what you want and how to do it then do it. we cant hold your hand along the way.</TD></TR></TABLE>
wow, you ARE new, huh?
Old Jul 21, 2005 | 10:13 AM
mrdeadman's Avatar
They let me pick
Default Re: ADVICE NEEDED (LSvtec03)
dont be a jerk, that is simply my opinion on the matter and that is what i would do. so f-off.
Old Jul 21, 2005 | 10:26 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">dont be a jerk, that is simply my opinion on the matter and that is what i would do. so f-off.</TD></TR></TABLE>
i think there's been some extra internet tough-guys lately.
Old Jul 21, 2005 | 12:10 PM
2G0S0R1's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">
wow, you ARE new, huh? </TD></TR></TABLE>
I dunno bout the tuff guy stuff, but I didnt see much wrong with his informative post. I mean, why spend all the extra for vtec if he is going to boost. I love having vtec, but a non-v has just as much if not more potential for power(turboed) as the vtec.
Old Jul 21, 2005 | 01:32 PM
NuclearB18B's Avatar
i think there's been some extra internet tough-guys lately. </TD></TR></TABLE>
i've noticed that too...
pnoipj89
Nov 21, 2008 09:54 PM
Magik123
Aug 3, 2007 11:32 PM
dixie Normas7
15
Apr 14, 2006 03:46 PM
RSRintegra90
May 11, 2005 08:09 AM
moondoggieoo7
Jan 14, 2004 05:00 AM
