Starting problem... plz help
Old Jul 20, 2005 | 08:02 PM
Galland's Avatar
Default Starting problem... plz help
Ok, I've been having this problem for a while now.
Last year I rebuilt my motor. New pistons 82.5mm, shotpeened rods, new bearings, front/rear seal, balanced everything, block deck machined .35mm, and head machined .5mm. I also put in new bearing here and there, and a GSR water pump. Just recently I put a new adjustable fuel pressure regulator in a tuned it about 5psi higher then stock. I also just put a new Modine radiator, and a Main fuel relay.
Now, my car starts up just fine when its cold, but lately it has been idling rough like its only running on 3 cylinders when cold. Once warm it runs fine for a while and then idles up and the check engine light comes on. I checked the code and it says code 6 "High coolant temp" but the gauge says its running at normal temp.
After its warmed up, if I turn it off and then go to start it back up, it just turns over like its flooded and then after a while it might start (all the while with my accelerator floored).
Old Jul 21, 2005 | 03:45 PM
Galland's Avatar
Default Re: Starting problem... plz help (Galland)
come on guys.. someone has to have some ideas
JasonST
15
Mar 10, 2022 08:46 PM
3rdgenintegra48
Apr 8, 2008 10:32 AM
hydroflip
Jul 7, 2007 03:45 PM
garrybloom
Oct 7, 2004 04:17 PM
jabenne
Apr 4, 2002 05:50 PM
