02 sensor
Old Jul 19, 2005 | 09:30 AM
Baron55's Avatar
Default 02 sensor
How can i tell if my 02 sensor is bad?
Old Jul 19, 2005 | 10:06 AM
Datac9991's Avatar
Default Re: 02 sensor (Baron55)
Is your Check Engine Light on?
If it is, do you have a buddy at a shop?
Have him or someone use a scanner on your computer to find out the code it is throwing...that should get you most of the way there!
I'd say chances are, if there is no CEL, then your o2 sensors are probably good to go. But certainly consult a Pro.
Old Jul 19, 2005 | 10:18 AM
numbnuts22715's Avatar
autozone does that for free, so he doesnt need a buddy at a shop.
Old Jul 20, 2005 | 06:11 AM
Baron55's Avatar
No cel, but I dont know what else to do about my horrible mpg...It doesnt bother me as much but i see you guys getting like over 250 and yesterday i got 90 on a half tank of normal driving with ac...Did all my maintenance...whats next? It Would be nice to get the numbers you guys get.
Old Jul 20, 2005 | 07:41 AM
Im in the same boat as you, terrible gas mileage and it sucks cause its so expensive now. Ive got no idea what else to do, ive run out of ideas.
Old Jul 20, 2005 | 08:23 AM
internetautomart's Avatar
what year is yours? 95 and down won't neccessarily throw a code.
how recently have you done a tuneup?
a slow responding O2 won't neccesarily set off an engine light but it will affect gas mileage.
Old Jul 20, 2005 | 08:54 AM
Baron55's Avatar
I have a 98 gsr. I did a full tune up about 2 months ago.
Old Jul 20, 2005 | 02:06 PM
integra racr04's Avatar
i have bad milage too, gas sucks... if u did the tune up, and ur not trowing a code, try taking the sensor off, and cleaning it, there could be dirt and other **** stuck up it, id clean all your sensors to eliminate the problem, other wise , it could be a fuel problem, or a electronic problem... hope it works out for you...
Old Jul 21, 2005 | 09:32 PM
Baron55's Avatar
well, I think my piston rings are worn a bit...If I start it up and rev it high i get a bit of smoke..but once its warm, no smoke...and I have to give it about 1/4 quart of oil(mobile one 10w-30) if i drive hard for a bour 2-3 days...this normal? And if my rings are worn, is this screwing my mpg?
VeeSykkz
14
Dec 16, 2014 07:31 AM
myst
May 18, 2010 10:52 AM
illmatic1085
May 27, 2006 11:18 PM
Cuong-nutz
26
Nov 7, 2005 10:04 PM
cyrixvsp2
Jun 10, 2003 05:02 AM
