What Does Rebuild The Engine Include?
Old Jul 20, 2005 | 09:38 AM
dabiddan's Avatar
Default What Does Rebuild The Engine Include?
Hey,
I was wondering what do they change when they rebuild the engine? Thanks For Any Help Givien
Old Jul 20, 2005 | 09:41 AM
s2kdre's Avatar
Default Re: What Does Rebuild The Engine Include? (dabiddan)
pistons rings and rods and main and rod bearings
Old Jul 20, 2005 | 11:38 AM
Racermech's Avatar
Default Re: What Does Rebuild The Engine Include? (jdmhonda)
^^ all of that unless other parts are trashed. Alos all of the gaskets/seals fluids
Old Jul 20, 2005 | 11:48 AM
Honduh Chicken's Avatar
I fry gay turkeys
Default Re: What Does Rebuild The Engine Include? (Racermech)
Not to mention, if done properly, they machine the cylinders and mill the head and block and replace the head studs, water pump and timing belt.
Old Jul 20, 2005 | 12:38 PM
SithTeg's Avatar
upper gasket kit change out to refresh head $200
resurface head $40
deck resurface and hone block $60
new piston ring set $150
main bearings, rod bearings, thrust washer $200
pan gasket $20
oil pump $200
water pump $75
timing belt $60
belt tensioner $60
new accessory belts $60
new cap, rotor, wires, plugs, fuel filter $100
new coolant, oil, filter, air filter $75
clutch kit $300
resurface flywheel/new $50/$200
Old Jul 28, 2005 | 09:15 AM
dabiddan's Avatar
how much does rebuild cost? thanks for any help given
Old Jul 28, 2005 | 09:19 AM
I fry gay turkeys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dabiddan &raquo;</TD></TR><TR><TD CLASS="quote">how much does rebuild cost? thanks for any help given</TD></TR></TABLE>
Figure about a thousand with machine costs.
Old Jul 28, 2005 | 11:14 AM
ernald711's Avatar
Default Re: What Does Rebuild The Engine Include? (SithTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SithTeg &raquo;</TD></TR><TR><TD CLASS="quote">upper gasket kit change out to refresh head $200
resurface head $40
pan gasket $20
oil pump $200
water pump $75
timing belt $60
belt tensioner $60
clutch kit $300
pretty much sums it up
Old Oct 27, 2005 | 08:00 PM
BoostnSD's Avatar
Default Re: What Does Rebuild The Engine Include? (ernald711)
I'm trying to find out how much a rebuild in SoCal would actually cost. Has anyone actually had one done. Is that price a guestimate or do you actually work at a shop?
Old Oct 28, 2005 | 03:07 AM
91IntegraX's Avatar
bump
Old Oct 28, 2005 | 06:58 PM
BoostnSD's Avatar
Default Re: (91IntegraX)
^^Bump^^
89B16Civic
44
Jan 28, 2006 09:50 PM
EJ1 wilcox
Jun 18, 2005 08:19 AM
J.B.
May 6, 2005 08:42 AM
acuracy r
Feb 9, 2005 04:59 PM
schwett
Apr 24, 2002 08:37 PM
