idling issues
Old Nov 2, 2006 | 12:15 PM
93JDMB18C's Avatar
Default idling issues
Well when my car is first started, my rpm's are bouncing from 2500-3000 and back and forth for a good 2-4 minutes. It then proceeds to lower itself while still bouncing by 500 rpm's before finally staying constant around 800 rpms. Is this because it is about 45-55 degrees outside and my car just needs to warm up longer or is it something more prominent?
Old Nov 2, 2006 | 12:21 PM
aaronISthrowed's Avatar
Default Re: idling issues (93JDMB18C)
All cars idle high when they are 1st warming up, once they get warmed up they idle will drop to normal.
Old Nov 2, 2006 | 01:06 PM
95 integra's Avatar
Default Re: idling issues (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">All cars idle high when they are 1st warming up, once they get warmed up they idle will drop to normal. </TD></TR></TABLE>
No joke, however they dont bounce 500rpms constantly while doing so. Check your FITV (theres a thread somewhere), then for air in your coolant and then your IACV. If it idles down eventually then its almost got to be one of those 3 items. BTW, have you done anything recently/right before this started happening?
https://honda-tech.com/zerothread?id=699787
BTW, the FITV is under the throttle body and the IACV is on the backside of the intake manifold.
Old Nov 2, 2006 | 01:45 PM
93JDMB18C's Avatar
No i didn't really do anything to the car before this started to happen. One day the maintenance light came on, and I cleared it using the reset button because i have a motor swap. I was told that it had nothing to do with my current engine and that it dealt with a timer and how many miles you put on the car.
Old Nov 2, 2006 | 02:03 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93JDMB18C &raquo;</TD></TR><TR><TD CLASS="quote">No i didn't really do anything to the car before this started to happen. One day the maintenance light came on, and I cleared it using the reset button because i have a motor swap. I was told that it had nothing to do with my current engine and that it dealt with a timer and how many miles you put on the car.</TD></TR></TABLE>
Indeed, the maintence light has nothing to do with anything but the little timer box under the dash.
Zee.I
Jul 11, 2021 11:36 PM
Paprika
May 8, 2007 03:18 PM
Freshsho
May 25, 2005 12:49 PM
jokr78
Dec 15, 2004 01:47 PM
Br1anPham
Feb 2, 2004 05:29 PM
