Help needed fast PLEASE !!!!!!!
Old Nov 3, 2006 | 10:03 PM
PhatTeg86's Avatar
Default Help needed fast PLEASE !!!!!!!
i'm in trouble don't know whats going on
here is the situation
i press the clutch in and it won't let me in any gear....
what would it be ???? i need to know what $$$ repair/maintance is required
Thanks to anyone who can help
Old Nov 3, 2006 | 10:22 PM
davidluko's Avatar
Is that with the car on or off? If when on, then check if the clutch MC reservoir has fluid and check around the MC and along the path of the clutch line for leaks.
Old Nov 3, 2006 | 10:29 PM
PhatTeg86's Avatar
Default Re: (Hatch_R)
srry noob
whats MC ??? and where is it ?
Srry again
Thanx for all your help
Old Nov 3, 2006 | 10:30 PM
PhatTeg86's Avatar
Default Re: (PhatTeg86)
also could it be synchro's and if yes how much would it approx. run me ?
Thanx
Old Nov 4, 2006 | 06:58 AM
aaronISthrowed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">Is that with the car on or off? If when on, then check if the clutch MC reservoir has fluid and check around the MC and along the path of the clutch line for leaks.</TD></TR></TABLE>
MC is Master Cylinder, see if there is fluid in there.
Old Nov 4, 2006 | 07:46 AM
PhatTeg86's Avatar
Default Re: (aaronISthrowed)
sure thing will do
i'll keep you guys posted
Old Nov 4, 2006 | 08:28 AM
Racermech's Avatar
When you press the cluth pedal does it feel like there is some resistance, or does it just drop to the floor?
Old Nov 4, 2006 | 08:50 AM
jdm_bones's Avatar
Default Re: Help needed fast PLEASE !!!!!!! (PhatTeg86)
wow, how can you not know a clutch master cylinder! Please take it to a professional If you don't where it is and what it is, you need to just leave it to the pros...And I am not making fun of you, just common sense. It's good to know the basic's on the functions of your car. I mean, I know you what help and all, but we can only do so much for you. Please check the fulid and for leaks as posted above. See if it goes in gear with it off...It's also very common for Itegra's not wanting to go into 1st gear or Reverse sometimes...So if it doesn't want to go into 1st try Reverse and once the car begins to roll, shift into 1st.. I recommend that you do a transmission oil change, and you a filter when draining, then check for any metal shavings...Keep us posted....Good luck, have a friend who is mechaicly inclined help you!
Old Nov 4, 2006 | 09:11 AM
Dc2 Joe's Avatar
Default Re: Help needed fast PLEASE !!!!!!! (jdm_bones)
i had thios same problem. i check the mc it had no fluid so i threw some in and bled the clutch and now it fine. (my ? is were the hell did the fluid go i have no leaks) not trying to jack your thread but just thought it would be pointless to make a new one
Old Nov 4, 2006 | 09:56 AM
PhatTeg86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">wow, how can you not know a clutch master cylinder! Please take it to a professional If you don't where it is and what it is, you need to just leave it to the pros...And I am not making fun of you, just common sense. It's good to know the basic's on the functions of your car. I mean, I know you what help and all, but we can only do so much for you. Please check the fulid and for leaks as posted above. See if it goes in gear with it off...It's also very common for Itegra's not wanting to go into 1st gear or Reverse sometimes...So if it doesn't want to go into 1st try Reverse and once the car begins to roll, shift into 1st.. I recommend that you do a transmission oil change, and you a filter when draining, then check for any metal shavings...Keep us posted....Good luck, have a friend who is mechaicly inclined help you! </TD></TR></TABLE>
I know what Master Cylinder is i just didn't know the shorthand writings on parts such as MC ...?!? by the way i checked no leaks and fluid level is fine ??!??
I think its time to buy a new clutch
I will be getting one sometime by tues-thurs next week lol i mean i bought on online waiting till it comes in now
Thanks a lot JDM_BONES you been a whole lot of help so as everyone else who participated in this post Thank You fellas don't know what i would've done with out you
Old Nov 4, 2006 | 09:58 AM
PhatTeg86's Avatar
Default Re: (Racermech)
Its feels fine like usual sometimes hollow when you press in
Old Nov 4, 2006 | 10:23 AM
Sam92Teg's Avatar
I remember a post where a guy thought his clutch was out, but it was only his axle.
Old Nov 4, 2006 | 11:46 AM
JoePSI's Avatar
Default Re: (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatTeg86 &raquo;</TD></TR><TR><TD CLASS="quote">Its feels fine like usual sometimes hollow when you press in </TD></TR></TABLE>
Try Pumping the clutch pedal if it feels 'hollow' and see if pressure gets built up then try to dis-engage the clutch. Mine did the same thing, mine was an issue with the throwout bearing.
Old Nov 4, 2006 | 05:12 PM
PhatTeg86's Avatar
Default Re: (JoePSI)
same here i was at the shop early in the morning today and the guy who took the tranny apart to check on some things cuz i thought it was my synchros (whew thank god not) told me it was my throwout bearing and recommend me to change clutch asap cuz it was gonna go out in a day or two.... so i went up on ebay to check some clutch kits out and get something decent for the right price and here is what i got http://cgi.ebay.com/ebaymotors...wItem
Tell me guys what ya think about it
Thanks ahead
Later
Old Nov 4, 2006 | 05:30 PM
jdm_bones's Avatar
Thanks a lot JDM_BONES you been a whole lot of help so as everyone else who participated in this post Thank You fellas don't know what i would've done with out you </TD></TR></TABLE>
Your welcomed bro!
Old Nov 8, 2006 | 05:40 AM
qazaq's Avatar
Old Nov 8, 2006 | 06:36 AM
Lauj87's Avatar
check out ebay when you buy your clutch they have some pretty nice clutch and flywheel combos fro around 300-350. i got my exedy clutch and flywheel from ebay and i love it :-D
cleanej2
18
Feb 1, 2008 11:42 AM
BiGcAmBoDiAnSaUsAgE
12
Oct 30, 2006 09:04 PM
KloC 95 EG
Mar 13, 2006 09:18 PM
Tomatohatch
May 10, 2004 09:19 PM
hollaback6
Feb 28, 2004 10:12 PM
