Help diagnose starter problem
Old Nov 6, 2006 | 08:44 AM
vactor's Avatar
Default Help diagnose starter problem
i have a 1994 acura integra GSR. here's my issue. just a couple of days ago it became difficult to start. full charge on abttery, turn the key, all electronics turn on but starter does not engage. i then "shake" or "rock" the car a bit and it then usually cranks and starts. i think i need a new starter (12 years old) ... any simply way of checking? i think replacing it is easy to do. do i even need to jack up the car? anything i should be aware of when changing starters? thanks!!
Old Nov 6, 2006 | 10:28 AM
aaronISthrowed's Avatar
Default Re: Help diagnose starter problem (vactor)
You may as well get a new one they are not very expensive. You also don't have to jack up the car to take it out, its not very hard to do.
Old Nov 6, 2006 | 10:37 AM
skunked's Avatar
yep, sounds like the starter is taking a crap. Any manual B series starter will work.
Old Nov 6, 2006 | 02:57 PM
sohc_coupe24's Avatar
just take it to a local auto parts store..i believe they can check the condition of the starter for free. As for taking out the starter, its just a matter of a few bolts, there is no need to jack up the car
Old Nov 6, 2006 | 08:26 PM
GSRteggy00's Avatar
remember to disconnect the neg terminal onthe battery
crazyhouse2011
May 23, 2013 08:23 PM
TheCrimsonGhost666
Feb 28, 2010 06:53 AM
JDMtype Eg6
Oct 22, 2009 04:26 PM
ThatsTheTruth
Dec 7, 2006 06:40 AM
TiffanyJJ08
Oct 3, 2005 12:35 PM
