overheating?
Old Nov 1, 2006 | 07:38 PM
SaMMaE01's Avatar
Default overheating?
My integra recently started overheating. not because of lack of fluid, and the fans arent broken, they work, but whatever sends a signal that says "hey your **** is overheating" is loose. Whatever that sensor or whatever that is back there works but is loose. because when i let my car sit, idle. when it gets hot like halfway mark. fan dont turn or or nothing. even in secondary position but when i wiggle that plug or sensor or whatever. the fan starts to work? anyone know what that plug is or whatever?
Old Nov 1, 2006 | 07:49 PM
95 integra's Avatar
Default Re: overheating? (SaMMaE01)
Fan switch is a brown plug/sensor on the thermostat housing (check the backside of the engine, by the transmission/starter area).....or follow the lower radiator hose up (it connects to it). Sounds like you already narrowed it down to wiring though.....so Im not sure if that helps or is the information you were looking for.
Old Nov 2, 2006 | 12:18 AM
SaMMaE01's Avatar
ok cool. Does anyone have a picture of that side of the block to show the Fan switch ? That would really be helpful. I'm at work right now so I can't really go out to my car and peep it out
Old Nov 2, 2006 | 09:33 AM
95 integra's Avatar
Default Re: (SaMMaE01)
Its the brown plug circled in red.....its a hard area to get to on a GSR with the intake/distributor in....its easier to get to on a LS/B16 due to the intake manifold design.
Old Nov 4, 2006 | 03:09 AM
SaMMaE01's Avatar
kew, thanks for the pic man ! is the ls and GSR plug the same? I went out to my car right now and even tho its dark it seems like my brown plug aint that big. but I'll have time to check it out tomorrow. I'll let you know wassup
Old Nov 4, 2006 | 08:29 AM
yee SERIOUS's Avatar
if your fans are working, do you think it's a bad fan switch?
you should try doing a coolant flush to make sure there's no air bubbles in the lines.
you could always get a koyo aluminium radiator. my car doesn't even get to full operating tempature. hahahahaha
Old Nov 4, 2006 | 10:09 AM
95 integra's Avatar
Default Re: (undercoverdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">
you could always get a koyo aluminium radiator. my car doesn't even get to full operating tempature. hahahahaha</TD></TR></TABLE>
Then you have a bad thermostat, because the thermostat stays closed (which means no fluid is moving through the radiator) until the car is warmed up.
Old Nov 4, 2006 | 11:01 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (95 integra)
/thread jack
My needle stays at the line before half way. Is that normal operation temperature?
To OP my 00 LS fan switch looks like the 1 in the pic.
Old Nov 5, 2006 | 07:30 AM
Default Re: (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">/thread jack
To OP my 00 LS fan switch looks like the 1 in the pic.</TD></TR></TABLE>
normal operation temp is half way mark. my needle usually only goes to quarter way since i have a new full size koyo. i don't even have my slim fans plugged in. lol never over heats.
Old Nov 5, 2006 | 09:32 AM
Sam92Teg's Avatar
Normal operating temps can vary slightly when looking at the temp gauges of our Integras. Differences in the thermostat used and condition of temp sensors that feed the gauge, and the gauge itself can cause slight variances. Make sure your temp is in the proper operating RANGE and that it doesn't fluctuate.
The previous poster stated that the proper operating temp is at the half way point on the gauge. For his car this could be true, but mine has never reached the half way point since I have owned it except for when the water pump went out and on another occasion when the original radiator pooped out. My car is a 92 RS, and almost all of the 2nd Gen posts I read on G2IC give their operating temp on the gauge as being somewhere between 1/4 and 1/2.
When I changed my thermostat, the temp gauge needle gave a slightly different reading, but still way short of the 1/2 mark on the gauge. BTW, I have 300,500 miles on my integra, driven hard and always reliable, I have never been left stranded.
Louie9332
May 18, 2017 04:18 PM
97civicdx
Jul 20, 2010 05:04 AM
righteyeblind
Jun 30, 2008 03:02 PM
ITB
Dec 5, 2005 06:56 PM
JDM_SiN_CiViC
May 8, 2003 10:46 PM
