ABS Light On
I'm obd2 so I have to find a plug device. Just thought someone might have an idea since it is the ABS light specificly so there must be something going on with that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH »</TD></TR><TR><TD CLASS="quote">I'm obd2 so I have to find a plug device. Just thought someone might have an idea since it is the ABS light specificly so there must be something going on with that.</TD></TR></TABLE>
A paper clip will also work for OBDII. Look at the link I posted. It will take you less than 5 minutes.
Didn't know it worked for obd2 as well, I've done it on countless other cars that were obd1. Thought you need the scanner, thanks for clearing that up
My ABS light went on a few weeks ago and before I even tried to pull any codes I bled the abs pump by attaching a hose to the bleeder screw and opening the screw. After that the light went off.
