snapped a belt... which one?
on my way home from the lube shop after they changed my oils and oil filter my battery light came on and i noticed a knocking sound in my car, i pull over at kfc and expletiveing one of my belts r snapped and 1 of the wheels it was on came off because the screw came out or something, which belt is this? and how do i fix this, can i jus screw the wheel back in and add a belt? ,
its one of the lower belts under the driver side motor mount, its in a hard to reach place.
can any1 point me in the right direction.
While your at kfc can you pick me up a twister?
Thanks
On a more serious note, does your AC work if you even have it? Does your powersteering work? If both those work then you snapped your alternator belt if one of those doesnt work thats the belt you snapped. As soon as you get the belt replaced and inspect the pulley for dammage you should be good to go!
Thanks
if u lived here for giving me this info i would buy u a twister haha... but anyway bro im thinking it was altinator belt too, cause the battery light is on, that wouldnt come on if the altinator belt wasnt the one snapped im thinking , due to the power not being givin its getting it from my battery therefor pooping the light. oculd be wrong, but my steering is fine and i havnt tried the a/c yet, but is it drivable liek this? i need to get it to a shopo, where can i bu ythese belts anywhere around town or do i need togoto honda.
also is it hard to change this, can any1 provide with a diagram or step by step on changing altinator belt
and one of the pulleys came off, the on under the top belt is off, looks like the bolt or w/e came out and i have the pulley or wheel sitting on my desk with n obolt or anything....
you can drive it..but you are going to kill your battery. the whole point of the alternator is to keep the battery charged.
Hill4589
Nov 14, 2008 12:26 PM
CALC!_JUST_du_IT!
Jun 10, 2008 12:55 PM
Atiyeh
May 30, 2002 03:34 PM
