1992 integra died on the street
I have a 92 integra RS automatic. I was driving down the street and all of a sudden my car completely died when it died I noticed that the check engine light turned on. I pulled to the side and put a jump wire in my obd tester i got no flashes. When i got it home(BY AAA) i startrd messing with it and the first thing i noticed was that when i turned the key i did not here the fuel pump kick in or the fuel injectors eather so i went to the junk and got a fuel pump relay i found it bought it and put it in but no luck. so i moved to the next step witch was dropping the tank to check the fuel pump but it works fine. the car cranks over and everything but it does not fire up please help on what i should try next im frusterated.
Re: (rockofcali)
i would check:
1) If your injectors are getting fuel
2) Getting spark
3) Check all fuses
4) Try another ecu/ Double check all ecu pins on the harness are in tact
5) Change out dizzy, more then likely it could of gone bad
6) check to see if your timing belt hasnt snapped
i would try those..and get back to us
2) Getting spark
3) Check all fuses
Re: 1992 integra died on the street (Black 92)
Cool thanks for the ideas ill check all of them out and ill get bak at you guys. By the way my buddy has a crashed 1990 integra manual trans. and he said he would let me use the ecu to test it out is it compatible???? thanks for all your help.
Your friend want to sell that 90 teg let me know cody_james_morris@yahoo.com
* B A N N E D *
Re: 1992 integra died on the street (cmorris87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmorris87 »</TD></TR><TR><TD CLASS="quote">Your friend want to sell that 90 teg let me know cody_james_morris@yahoo.com</TD></TR></TABLE>
what does this have to do with the thread? noob
n15sk4
07-13-2020 04:41 AM
deckster333
09-10-2006 10:43 AM
