help asap!!!!!! :(
Old Feb 7, 2008 | 05:28 PM
boosted_ef9's Avatar
Default help asap!!!!!! :(
okay so i have a dc2 integra ls 4dr... and yesturday i broke my drive shafts i was wondering if somebody could tell me the tools i will need and how to remove them the easyest i just bought a pair of type r drive axels from acura as a replacement and i need to get this dont asap cuz this cars my winter beater! HELP thanks alot
cheers
Old Feb 7, 2008 | 05:32 PM
red02s2k's Avatar
why would you buy axle's from acura!!! buy from autozone you get a lifetime warranty plus they are cheapier
Old Feb 7, 2008 | 05:38 PM
all-mtr-teg's Avatar
Default Re: help asap!!!!!! :( (boosted_ef9)
Is this your other account?
https://honda-tech.com/zerothread?id=2218170
Old Feb 7, 2008 | 07:34 PM
no this is my original account..and i bought them from acura because im from canada lol n we dont have that,we have part source, but can somebody please help me bout my questions?
Old Feb 7, 2008 | 07:53 PM
qazaq's Avatar
car jack + jack stands / lift
breaker bar with like 23mm socket (don't remember exact size) to loosen the axle
socket 17 and ranch 17 to unbolt strut fork (you can take the fork off if you want, for ease)
big flat-head screw driver to get the axle out of trasmission
Driver side:
loosen the axle first, then lift up the car
take off the wheel
take out 17mm bolt holding the strut fork
take off the fork <-- up to you
steer the column to the right to slide the axle out of the hub
slide the screw drive between axle and transmission and pop it out
Pass side:
same **** but take out the bolts holding half shaft instead of using screw driver, axle should come right out
Old Feb 7, 2008 | 07:55 PM
qazaq's Avatar
also, i dont think 4 door integra is dc2. it should be db from what i know
Old Feb 7, 2008 | 08:12 PM
Default Re: help asap!!!!!! :( (qazaq)
lmaoooooo ohh yeahhh srry bout that but thanks for the great info realli i apprecite it
Old Feb 7, 2008 | 09:04 PM
Before you start, its a 32mm not 23mm to remover the spindle nut. And have a set of metric tools, 10, 12, 14 17mm are really common on our cars, a pry bar or big screw driver, and maybe even a hammer to pop out the axle. Good luck
Toe_fur
Transmission & Drivetrain
Nov 8, 2012 06:20 AM
dansaleen_04
Sep 10, 2006 05:58 PM
baonest
Aug 28, 2002 10:03 AM
