b18c1
Old Feb 5, 2008 | 10:10 AM
nogutsnoglory77's Avatar
Default b18c1
ok i am currently building a 1994 b18c1. the block is bare and im really confused on which pistons i should go with. i was looking to go turbo but i dont really have the money to build the motor and buy all the turbo parts to go with it. my question is . would it be safe to run a 9:0 comp ratio with a good tune until i have the parts to turbo the car? the head will be a b16a2
Old Feb 5, 2008 | 10:19 AM
91redteg's Avatar
Default Re: b18c1 (nogutsnoglory77)
9:0??? do u mean 9:1? because that is a kick *** comp ratio for boost
Old Feb 5, 2008 | 10:26 AM
Default Re: b18c1 (91redteg)
well i found a set of arias pistons for sale on a kick *** deal .. and they are 9:0 flat top pistons .. http://www.atomicspeedware.com...s.htm ... part number AR-3310402
Old Feb 5, 2008 | 12:11 PM
Schister66's Avatar
Man U FTW
I'm not sure where you come from, but around here $495 for a set of pistons with rings is a pretty bad deal. You can get a set of new pistons in the Marketplace for around $435. Also, i would plan a bit more before jumping into something with this build. Granted, you can use 9:1 for most any turbo build, but just because its common, doesn't mean that its the best option for you. For example, i'm going to be running a 9.8:1 in my GSR on E85. There's no reason to drop the compression ratio if there's a fuel with an octane level high enough to support your goals.
Spody02
Apr 30, 2008 09:24 AM
Bignel00
Dec 17, 2007 04:47 PM
HondaHead211
Aug 13, 2006 09:55 AM
turbochargeb18c
May 21, 2005 06:09 AM
elementmilwaukee
May 5, 2004 10:14 PM
