to much vacuum ?
Old Apr 11, 2008 | 09:26 AM
mikex1021's Avatar
Default to much vacuum ?
is it possible to have to much vacuum, im pulling 22-25 hg of vacuum in my turbo gsr, at idle it smokes alot of blue smoke but when i get on it, no smoke, also my idle is at 1700rpm and ive tried everything to bring it down, nothing works, any help would be great. thanks
Old Apr 11, 2008 | 01:20 PM
Perfectionist's Avatar
Default Re: to much vacuum ? (mikex1021)
Vacuum is a function of RPM and throttle position. If the engine couldn't get enough air, it would cause high vacuum readings. Too high and the engine would shut off.
However, you claim an idle of 1700RPM, which would indicate the engine is getting too much air (open vacuum port, intake leak, stuck throttle plate, etc)
Smoke at idle is ussually a sign of worn valve guides.
Old Apr 11, 2008 | 06:46 PM
mikex1021's Avatar
Default Re: to much vacuum ? (Perfectionist)
well i had the valve guides replace about 10-15k ago with bronze guides, and the motor has about 1k since my rebuild.
Old Apr 12, 2008 | 04:07 AM
mikex1021's Avatar
no one has ne ideas
blakeasul
May 3, 2018 07:41 PM
scubacamper
Oct 29, 2015 05:48 AM
Space Cadet
Oct 19, 2010 05:01 PM
lsxtreme81
Apr 20, 2007 05:39 PM
autoxthis
Feb 12, 2004 09:17 PM
