DA code 14 wont go away
Old Apr 13, 2008 | 02:20 PM
91daINTEGRAda91's Avatar
Default DA code 14 wont go away
I just recently turboed a 91 integra it has stock ecu and stock injectors but the vehical has a 97 obd1 motor in it with the obd0 wiring harness and ecu. the code is for a ivac sensor and i replaced it but the code is still there? any help would be appreciated the cars turbo is off im just trying to get it running right and also it is runing very rich?
Old Apr 13, 2008 | 06:11 PM
shad0wslay3r's Avatar
Default Re: DA code 14 wont go away (91daINTEGRAda91)
You are running a turbo with a stock ecu & injectors?
Old Apr 13, 2008 | 06:21 PM
db-1charlie's Avatar
Default Re: DA code 14 wont go away (shad0wslay3r)
ya man you can't run a turbo with a odb0 ecu. it wont run right at all especially when you start putting on boost lbs.
Old Apr 13, 2008 | 07:16 PM
Default Re: DA code 14 wont go away (db-1charlie)
i have a chipd ecu and 550 injectores for it but im not puting them in yet untill the vehical is runing perfect befor i hook the turbo up
EG RussE
Nov 27, 2016 09:18 PM
dre33333
Nov 22, 2012 05:17 AM
initialR
Jan 10, 2005 10:06 AM
