Invidia Test Pipe
Old Apr 9, 2008 | 12:43 AM
dc4drewb's Avatar
Default Invidia Test Pipe
Im running stock 2 1/2 piping and recently bought an Invidia test pipe
for some reason flanges dont line up
tried rotatin it around and tried every single way possible but it did not want to bolt up correctly
knowing that invidia is made by RS*R too this is weird
manufacturer defect?
any opinions/ suggestions?
Old Apr 9, 2008 | 05:42 AM
crazyguy's Avatar
Default Re: Invidia Test Pipe (dc4drewb)
did u get the right test pipe for your car?
Old Apr 9, 2008 | 06:48 AM
jhammond_82's Avatar
Reject Papi
Default Re: Invidia Test Pipe (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">did u get the right test pipe for your car?</TD></TR></TABLE>
Old Apr 9, 2008 | 09:39 AM
dc4drewb's Avatar
yep it was check checked many times even product number was checked on the invidiausa.com website
Old Apr 9, 2008 | 09:46 AM
steveteggy92's Avatar
What kind of car?
Old Apr 9, 2008 | 10:29 AM
dc4drewb's Avatar
95 ls
Old Apr 9, 2008 | 05:07 PM
PACT man's Avatar
Default Re: (dc4drewb)
95 LS stock piping definitely isn't 2.5", more like 2", ITR is only 2.25". Is it both flanges that don't fit? There is a 2 bolt in the front and a 3 bolt in the rear of the test pipe and the coresponding exhaust pipes, correct? Is it the length that is different?
Old Apr 9, 2008 | 06:32 PM
bettsbanger's Avatar
Default Re: (PACT man)
thats correct pact man. i just did my invidia test pipe yesterday in fact on my 97 ls, and the size is 2 5/8 for the test pipe. i'm not 100% sure but you may need an after market exhaust of at least 2.25 inches or it won't bolt up. also why would you install a test pipe if your going from a 2.5 inch collector from your header to a 2 inch catback, there would be little to no results of increase in power. hope this helps and good luck with your exhaust!
Old Apr 12, 2008 | 12:27 PM
DiMpL3s.'s Avatar
Default Re: (bettsbanger)
i had the same problem...
i just got the pipe cut and fitted on at a muffler shop because i didn't wanna mess or try to get on the phone and talk to some one and have them say oyeah its the right one...
$amGD3
Feb 9, 2011 11:31 AM
Tong.Y
Jan 2, 2011 08:14 AM
dc4drewb
Apr 9, 2008 12:49 PM
sleeperaccordv6
Apr 18, 2002 11:44 AM
