H.I.D problem
Old Apr 9, 2008 | 10:14 PM
The_Ricky_Is's Avatar
Default H.I.D problem
i tried searching and i couldnt find anything.
i got some new hids and they wont work for some reason?
im sure the kit works, cause i tried plugging it in to another car and they turned right on.
does any one have an answer too this or has had this problem?
any help would be awesome
Old Apr 9, 2008 | 10:29 PM
bobmugen's Avatar
same thing happened to me
try buying a harness if the company you bought from makes them.
Old Apr 9, 2008 | 10:38 PM
Default Re: (bobmugen)
did the harness fix your problem?
im getting them from a buddy of mine.
there brand new in the box, and im getting them for a pretty good deal.
there xeon btw.
Old Apr 9, 2008 | 10:52 PM
bobmugen's Avatar
Default Re: (The_Ricky_Is)
yes it did but be careful where you put the wire, i had mine lying on some hot *** pipe and it burnt it but i taped it back and now its working perfectly
Old Apr 9, 2008 | 10:54 PM
thanks for the help buddy, i guess im gonna go order this and sex up the teg with it!
thanks again
Old Apr 9, 2008 | 11:04 PM
jdmdc22's Avatar
Default Re: H.I.D problem (The_Ricky_Is)
check ur fuses
Old Apr 9, 2008 | 11:38 PM
Default Re: H.I.D problem (jdmdc22)
i dont think its my fuses cause my regular bulbs work.
i did check them though
Old Apr 9, 2008 | 11:41 PM
ZE12O's Avatar
check the harness that plugs into your oem bulb supply. make sure the contacts actually plug into the harness.
kragen has some 9006 harness adapters that you can wire into the hid ballast wires.
voltmeter would insure that the ballast unit is getting power. good luck!
Old Apr 9, 2008 | 11:46 PM
Default Re: H.I.D problem (ZE12O)
thanks man
im really thinking its the harness that i have in there right now.
cause the ballast and bulbs are all brand new,
but im gonna try and get another set of harnesses and see if they work
thanks for the help guys
Old Apr 10, 2008 | 07:09 AM
mikeb01453's Avatar
make sure you have a clean ground or they wont work
nyuke
Lighting
May 14, 2010 06:35 AM
immajackuup
Dec 19, 2008 07:19 AM
vtek9
Lighting
Nov 14, 2007 12:54 PM
TURBODC4TEG
23
Sep 15, 2007 12:01 AM
