IS THIS RIGHT? (trans. question)
Old Apr 8, 2008 | 12:38 PM
ivan93egreppin210's Avatar
Default IS THIS RIGHT? (trans. question)
i just put my motor/tranny back together. i have my motor out of the car. i tried pushing the tranny fork back to see if i put everything back together right and i cant do it. is it supposed to be that hard? i can move it with a pry bar in between the case and fork but thats it. its an exedy clutch stage unkown.
Old Apr 8, 2008 | 03:42 PM
pokmijn's Avatar
Default Re: IS THIS RIGHT? (ivan93egreppin210)
did you use an alinment tools to make sure your clutch sits right.
Old Apr 9, 2008 | 08:12 AM
Default Re: IS THIS RIGHT? (pokmijn)
i hand tightened the clutch bolts. then i put the tranny on until it sat flush up to the block. i then tightened one bolt through the starter hole. i pulled the tranny back off and tightened the rest of the bolts up. when i reinstalled the tranny it went in with no problem. i read on a thread that once the tranny goes all the way in that it is aligned right. is this correct?
OBDII Integra
Sep 11, 2009 08:56 PM
REX90stock
13
Jan 17, 2008 06:40 PM
Nisif
Aug 20, 2005 04:39 PM
92-LS-Civic
Jan 31, 2005 09:20 AM
