turbo dumptube relocation suggestion.
Old Jun 16, 2006 | 06:29 AM
lv6l's Avatar
Default turbo dumptube relocation suggestion.
i'm running about 5lbs or less of boost on a t3/t4 in a sohc vtec. my downpipe looks like this.
the red is where my dumptube is pointing at right now. its about half an inch from touching the downpipe and is blowing exaust gas out constant, and is loud even when at idle. is the noise at idle normal for an open tube??
the green is where i was planning to connect the tube into but not sure if it will be efficent. i don't mine losing a few hp i just don't want any back pressure or anything to cause my turbo to go bad due to bad location. also i can't leave it open because cops are very strict about these things around my area and i also dont like the loud noise. so what do you guys think is the best relocation. thanks.
note: if pic dont work tell me.
Old Jun 16, 2006 | 06:48 AM
lv6l's Avatar
BUMP before i go to bed.
any inputs is apreciated.
Old Jun 16, 2006 | 06:56 AM
kordenbrock motorsports's Avatar
i think that would be a good location (red). but the cut may be difficult. that way the gases are going with the flow of the downpipe and not entering in perpendicular. or just dump it to the atmosphere (no tie in) . just a thought
brett
Old Jun 16, 2006 | 07:39 AM
lv6l's Avatar
oh thanks. i can't dump it into the atmosphere because its too loud and cops will pull me over instantly. california is very strict. so retarded. but thanks for your input.
anybody else before i start cutting?
Old Jun 16, 2006 | 10:00 AM
EK k kay's Avatar
Default Re: (lv6l)
Here's where Phil from Spoolin put mine
Old Jun 16, 2006 | 10:15 AM
oscarmayer's Avatar
put it at the lower connection point, but make sure it's at an angle tie in so it will dumb WITH the flow and not cause turblance when it is letting gasses by.
Old Jun 16, 2006 | 08:44 PM
lv6l's Avatar
i just finish putting mine in today. but the idle noise is still loud. what else could cause this? i can feel a leak from where it was welded. my friend and i weld it outselves. its a small leak though. you can feel a bit of air coming out from it, not much. could this little air still cause the motor to be very loud? oh also my downpipe is 3" and my exaust pipe is stock 2.25". maybe this is a concern also. thanks.
Old Jun 16, 2006 | 08:48 PM
boostednlinefor's Avatar
there should be nothing coming out of the wastegate dump tube at idle. is it adjusted correctly? the diaphragm might be torn.
Old Jun 16, 2006 | 10:24 PM
methos713's Avatar
Default Re: (EK k kay)
is the dumptube connected to the downpipe at an angle in that pic with the spooling setup? Or is it just connected and welded on at a certain degree? Would that cause back pressure?
Old Jun 17, 2006 | 12:16 AM
rudebwoy's Avatar
Default Re: (methos713)
old setup by SPOOLIN
new setup by RLD-FAB
Old Jun 17, 2006 | 04:16 AM
methos713's Avatar
Default Re: (rudebwoy)
that RLD-FAB setup is sic
Old Jun 17, 2006 | 05:40 AM
Autoworks's Avatar
I want to extend my dump like the RLD...that is a nice setup
Old Jun 17, 2006 | 07:23 AM
JDMCRX's Avatar
Default Re: (Autoworks)
open atmospher the best scares all the v8s away
Old Jun 17, 2006 | 07:51 AM
lv6l's Avatar
yeah scares v8 away but attracts cops. hehe. i think my diapham in my wastegate is busted. just to claify, its like a rubber thingthat suppose to hold itself down and not suppose to all come up? cuz mine doesn't look like it has good sucktion.
JokerX-1.6T
Jun 17, 2007 07:11 AM
tranceologist
Sep 17, 2005 12:58 AM
hawjboi
Jun 28, 2002 07:43 PM
bretx0r
Jun 19, 2002 10:28 PM
98lude
Sep 23, 2001 10:35 PM
