realistic hp and boost
Old Jun 15, 2006 | 03:16 PM
94integragsr's Avatar
Banned
Default realistic hp and boost
im going to get tuned on the 22nd and was asked how much boost im going to run ? i have a fully built lower end w stock sleeves , je 9;1 pistons, crower rods honda bearings, balanced and blueprinted ect , and block guard , also i will be tuning on a stock head. dp is 2.5 , exaust is 2,3/4 , 3bar map, 880cc injectors 55lph fuel pump aem fuel rail and regulator, sk2 pro intake manifold ,turbonetics .57 .63 ar t3to4e . clutch is stage 3 six puck, flywheel is 8 lbs. is 17 psi too much??????????
Modified by 94integragsr at 6:04 PM 6/15/2006
Old Jun 15, 2006 | 04:53 PM
Schister66's Avatar
Man U FTW
i hope 155lph is a typo....i would think 350whp range, but that depends on the engine too and your tuner........keep us posted!
Old Jun 15, 2006 | 05:02 PM
Banned
Default Re: (Schister66)
yeah 55 lph my tuner is going to be morgan with synapse motorsports in albany ny
Old Jun 15, 2006 | 05:37 PM
thomas@LPS's Avatar
17 psi should be fine on that setup.
Old Jun 15, 2006 | 06:24 PM
Banned
Default Re: (civic_ex_95)
im hoping for like 375 400 if possible
Old Jun 15, 2006 | 06:35 PM
93CX's Avatar
Default Re: (94integragsr)
First 155lph, now 55? Damn, I think you're going to need more fuel
Old Jun 15, 2006 | 06:39 PM
spooledex's Avatar
I got about the same setup and I put down 365@14 psi on pump with a very conservative tune. Stock head and DP are going to be factors though. should make about 400 whp on 18psi on your setup.
Old Jun 15, 2006 | 06:41 PM
tcontesh's Avatar
Default Re: realistic hp and boost (94integragsr)
you should be safe on 17 psi
after you get tuned you should post a dyno sheet or let us know what kind of #'s you made.
Dave_Dc2
Apr 21, 2009 03:29 AM
Civic Hx-T
Aug 26, 2005 10:57 AM
crx88fast
10
Apr 7, 2005 05:07 PM
boostedsohc91hb
14
Feb 13, 2004 09:13 PM
1sick4door
Dec 9, 2001 05:38 PM
