help! low compression test
Old Jun 12, 2006 | 12:41 PM
turboMEsilly's Avatar
Default help! low compression test
well just finish throwing in my b18b. everything seems fine, runs pretty strong. but its kind of smokey. so i decided to do a compression test. at first i did the test, i forgot to unplug the ecu fuse, and cranked only 4 times, it read 125 100 125 125. keep in mind this is my first time. so this time i read the instructions carefully, i pulled the ecu fused, and cranked about 10-15 times on wot, and my readings were 150 130 150 150 all across, isnt these numbers way too low? i did the car at operating temperatures as well same readings. i even threw a cap full of oil in and it jumped to like 195 195 180 185... so i dunno what to do. is it my rings? this motor is seeing boost real soon thats why im worried. thanks in advance for the help.
Old Jun 12, 2006 | 10:42 PM
Default Re: help! low compression test (turboMEsilly)
any help?
Old Jun 13, 2006 | 05:02 AM
oscarmayer's Avatar
yes they are low, the motor looks to be a high limage motor most likley. you most likley are going to have issues with it. time for a new one or rebuild.
Old Jun 13, 2006 | 05:41 AM
blueshark123's Avatar
Default Re: (oscarmayer)
The numbers will also differ from gauge to gauge. Your real concern is that the numbers shouldn't be too different. If a number is different from the rest by 20 then you have a problem.
97civic07gsxr
17
Mar 5, 2009 12:30 AM
-HONDA-
11
Aug 8, 2007 05:33 PM
cu3tip
Mar 14, 2004 09:03 PM
Zorro
Nov 26, 2001 09:42 AM
