Blown flange gasket.....
Old Jun 13, 2006 | 05:03 PM
SlowPokeEg's Avatar
Mike Jones
Default Blown flange gasket.....
I believe i've blown my (manifold to turbo) flange gasket. Should i just buy some of that "gasket material" and do a DIY gasket or is there somewhere with some high quality gaskets. It only happened when i turned the lil T25 up to 12psi so i need a little holding power...
Thanks for the help in advance.
Old Jun 13, 2006 | 05:05 PM
igo4bmx's Avatar
im running no gasket...
Old Jun 13, 2006 | 05:06 PM
iBrandon's Avatar
Default Re: Blown flange gasket..... (SlowPokeEg)
You can run without a gasket...many do...or you can try that high temp gasket sealer...the red/orange stuff, just a thin layer though....naturally the heat will expand the metal and force it to seal together, if you dont have huge gaps and knicks in b/w the mating flanges....
Old Jun 13, 2006 | 05:15 PM
SlowPokeEg's Avatar
Mike Jones
Default Re: Blown flange gasket..... (iBrandon)
Well, i've cranked all 4 bolts down as tight as i can get them and can still feel plenty of air (and hear it!) coming from the rear right bolt. I can also see that the Cast isn't meeting even with the bolt as tight as i can get it.
I think a gasket is the way to go here to assure proper pressure.
Old Jun 13, 2006 | 05:17 PM
iBrandon's Avatar
u let the car warm up? How big exactly is the gap?
Old Jun 13, 2006 | 05:46 PM
coneheadsracing's Avatar
Napa sells a coupld of the do it yourself gasket materials. One is for like 400 degrees, and one is for like 700. They come in fairly large sheets, i can prolly get you a part number if you wanted. I switched to the higher temp just last night. Went through both of my gaskets, third time now.
Anyone make metal gaskets, like they do for the exhaust manifold?
Old Jun 13, 2006 | 05:53 PM
SlowPokeEg's Avatar
Mike Jones
Default Re: Blown flange gasket..... (coneheadsracing)
Still does it at operating temp. maybe a lil smaller than 1/16? I'm not too sure.
Metal gasket would work. Let me know what you find out on that. You burned through the low temp ones you mean?
Old Jun 13, 2006 | 06:14 PM
jv314sg is the part number on my box for the higher temp stuff. Thats from Napa. Yes i burnt through the lower temp stuff. It has a coating, with metal mesh in the middle, but what happens is when you cut it, that mesh is exposed. Over time i was burning up the coating over the mesh, and thus making a whole. The newer stuff is a different coating, should work better. You'll need some tin snips to cut it. And if you put your manifold down on it, and dril through the holes, if that makes sense, you won't tear up your gasket. That works for many types of gaskets.
If you get this stuff and the part number doesn't work let me know, my buddy works at napa i'll get the right one. Its about one foot by three.
Like i said, if anyone one knows of metal ones
Old Jun 13, 2006 | 06:18 PM
sycamore
Guest
Posts: n/a
i would just buy a new gasket if you use the gasket maker or use no gasket you will most likly have a huge boost leak
Old Jun 14, 2006 | 08:58 AM
SlowPokeEg's Avatar
Mike Jones
Default Re: Blown flange gasket..... (sycamore)
OK, anyone know of a good place to buy a gasket for this?
I think i found one on ProStreetOnline.com, and it says T25 inlet gasket. Since the gasket is for before the turbo, that would qualify as the inlet and the one i need correct? Can't be too sure with these online orders...
Anyone else with any input?
Old Jun 14, 2006 | 09:20 AM
igo4bmx's Avatar
http://www.atpturbo.com/Mercha...e=GSK
swappedcx
Jul 30, 2006 03:00 PM
O16581724 5 2 5
May 28, 2006 12:35 AM
dester223
Dec 16, 2005 08:26 PM
jBj
Nov 18, 2005 03:31 PM
toolowsol
Jan 5, 2005 03:34 PM
