little black marks on cylinder walls?
i just ripped apart my block and i see some little black marks on the cylinder walls and a few on the crank journals. i know these are heat marks right? so whats the best way to get rid of them? will they come off in the degreaser tank? im getting the block dipped tommorow
the black marks are most likley caused by detonation. you shoudl consider tering the entire motro apart and have it check out for cracks nad stress fracturers. repalce the pistons and rings (hone block to next size up if it tests ok) to be safe.
IF that's the case, but I thin there's a good chance it is.
Aradin
Engine Machining & Assembly
07-20-2015 12:41 AM
POORMANT
18
03-13-2009 08:22 AM
