Injector clip wiring help *pic*
Wiring up my Precision injector clips, got a question about the wiring. I already know the wire colors for each injector. My question is, does it matter which wire goes where on the injector clip? See my d0pe! MSPaint diagram below, and note difference between wire placement in Fig 1 and Fig 2, and does that matter at all??
Re: Injector clip wiring help *pic* (boostedej1)
Are you sure that the wires are switched? It could be that the entire injector/injector clip assembly has been rotated 180*.
so which way is correct for the Precisions? My stock injectors were wired like Fig.1 with colored wire on left, and black/yel wire on right (if looking from front of car).
Re: Injector clip wiring help *pic* (VTteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTteg »</TD></TR><TR><TD CLASS="quote">Are you sure that the wires are switched? It could be that the entire injector/injector clip assembly has been rotated 180*.</TD></TR></TABLE>
the wires have not been soldered yet. and I dont think the injector clip is rotatable so I need to make sure they are connected correctly.
Re: (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">injectors don't have polarity.</TD></TR></TABLE>
agreed
Your first diagram is the stock way if you want it to be correct to OEM standards.
agreed
Re: (infulleffect)
Brining this back from the dead
So basically the injectors will function properly no matter which way they are wired but figure 1 is the stock way?
Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">Brining this back from the dead
So basically the injectors will function properly no matter which way they are wired but figure 1 is the stock way?</TD></TR></TABLE>
Yea. It is a coil your triggering inside the injector. They do not have polarity. Figure 1 is the stock way.
Tippyman
14
03-27-2006 08:55 PM
Mr. Vapor
05-07-2005 01:03 AM
