Anti-lag, has anyone tried this
Old 06-12-2006, 05:08 PM
red11secondcivic's Avatar
Default Anti-lag, has anyone tried this
ok i know this is kind of getto, but my car has a msd digital 6 in it and I am using the step retard at -9.9 deg, 2 step at 5200rpms, my nos fuel sylnoid all on 1 button a was able to build 6 to 7 lbs off the line. my ? is how could I make about 10 off the line
Old 06-12-2006, 05:49 PM
adseguy's Avatar
Default Re: Anti-lag, has anyone tried this (red11secondcivic)
Can't do it without adding fuel. Uberdata cuts the fuel for it's two step, you need another EMS
Old 06-12-2006, 06:05 PM
Default Re: Anti-lag, has anyone tried this (adseguy)
I don't use uber for 2 step I use my msd for that and im adding fuel with a nos fuel sylnoid. Im just wanting more boost off the line, will raising my 2 step rev limit from 5200 to say 6500 make a difference
Old 06-12-2006, 06:17 PM
adseguy's Avatar
Sorry, didn't see that you where adding fuel . No 5200 rpm should be enough I hope the turbo isn't a GT42R or something . I donno. When is the retard happening?
There are 3 steps to anti-lag (now I've never actually done this to any car so there may be other ways)
set an ignition retard RPM (5000rpm let's say)
set an ignition cut RPM ( 5200RPM)
set a fuel cut RPM (5500RPM)
What are your settings at?
Old 06-12-2006, 06:25 PM
ignition retard is set a 5200
ignition cut is a 5200 also
I have no fuel cut I add fuel a 5200 and it is a 57 63ar
Old 06-12-2006, 06:26 PM
adseguy's Avatar
Try setting it to what I said.
Old 06-12-2006, 06:30 PM
ok thanks, I'll try it on my way tho work
a1320honda
Engine Management and Tuning
05-10-2013 06:01 PM
dominidg123
06-02-2009 05:42 PM
LBR92DA-T
10-24-2003 07:48 PM
90Zcrx
11-01-2002 01:35 PM
JM Performance
10-24-2001 02:10 PM
Quick Reply: Anti-lag, has anyone tried this
