2 step....or 3 step
Old Jun 10, 2006 | 09:39 PM
mike93boost's Avatar
Default 2 step....or 3 step
ok i want a 2 step or 3 step on my new setup.. i know some programs come with 2 step but is it any good. should i go with msd? opinions on 2 step and 3 step please!
Old Jun 10, 2006 | 09:40 PM
A.E Motoring's Avatar
Default Re: 2 step....or 3 step (mike93boost)
i have a 2 step on my hondata
Old Jun 10, 2006 | 09:53 PM
Default Re: 2 step....or 3 step (SPNFEDEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2 step on my hondata</TD></TR></TABLE>
i read its not as good as msd though..
Old Jun 10, 2006 | 09:59 PM
roydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">
i read its not as good as msd though..</TD></TR></TABLE>
Could you please explain?
Old Jun 10, 2006 | 10:00 PM
Default Re: 2 step....or 3 step (roydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">Could you please explain?</TD></TR></TABLE>
i did alot of seasrching on here and read a bunch about it. have to find the links.
but what all else besides hondata has a 2 step? and how does it work. ive read some people complained because they cant doa good burnout with the 2step...but why is that? cant they disable it.. i dont know exactly how it all works, thats what im wanting to know.
Old Jun 10, 2006 | 11:18 PM
jdm'dc2sc61's Avatar
neptune has a 3-step i think
Old Jun 11, 2006 | 01:03 AM
Default Re: 2 step....or 3 step (jdm'dc2sc61)
crome has a 2 step, but when ever u want to change the settings u have to use a laptop, hondata u use a button, and u can set it any time u want
Old Jun 11, 2006 | 09:26 AM
which ones is ignition cut 2 step? i dont want a fuel cut 2 step.
Old Jun 11, 2006 | 09:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">crome has a 2 step, but when ever u want to change the settings u have to use a laptop, hondata u use a button, and u can set it any time u want</TD></TR></TABLE>
and what do you mean? when you want to enable and disable it, you have to use a laptop?
should i just get a msd 6AL and 2 step moduel?
Old Jun 11, 2006 | 10:24 AM
traction issuez's Avatar
hondata does fuel cut like a stock ecu would do.
hondata is also a switch like msd. u can wire it up to the clutch switch and everytime you depress the clutch fully it locks into the rev-limit or have a button to u can activate the limiter.
on my car, it's on the cruise control button.
Old Jun 11, 2006 | 10:30 AM
vietjdmboi's Avatar
with neptune the 2 step is user adjustable.. the preset rpm is whatever you set it at. mine is set at 3500 or you can bring the rpms up slowly to a certain rpm then stomp on it to hit WOT and it will 2 step there.
Old Jun 11, 2006 | 11:18 AM
Default Re: 2 step....or 3 step (traction issuez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traction issuez &raquo;</TD></TR><TR><TD CLASS="quote">hondata does fuel cut like a stock ecu would do.
i thought s200 did that but the s300 was different?
Old Jun 11, 2006 | 12:44 PM
stewie8apie's Avatar
uberdata also has a 2 step
Old Jun 11, 2006 | 01:08 PM
nerdsports's Avatar
but what all else besides hondata has a 2 step? and how does it work. ive read some people complained because they cant doa good burnout with the 2step...but why is that? cant they disable it.. i dont know exactly how it all works, thats what im wanting to know.</TD></TR></TABLE>
doesnt seem like you did a lot of research to me...
msd does ignition cutoff
crome/uberdata/hondata does fuel cutoff
2step usually means you can set 2 rpm limits
3step = 3 rpm limits.
if you look at the picture, you'll see module 1, module 2, module 3.
you can see 3 different rpms for 3 different functions.
the 2step only has 2 modules.
here's some info i found for the 3step on a vendor's website.
http://www.martelbrothers.com/....html
and the same for 2step...
should i just get a msd 6AL and 2 step moduel?</TD></TR></TABLE>
yes u need a lap top, crome 2 step is not used by a clutch switch or button, my friend has it on his ls vtec, and if he wants to change the rpm launch settings he would have to go back to the tuner and have him reset it
Old Jun 11, 2006 | 01:11 PM
nerdsports's Avatar
yes u need a lap top, crome 2 step is not used by a clutch switch or button, my friend has it on his ls vtec, and if he wants to change the rpm launch settings he would have to go back to the tuner and have him reset it</TD></TR></TABLE>
i think he was asking about enabling and disabling... not changing.
usually to enable "2step" (aka full throttle launch) you press in the clutch.
to disable, just depress the clutch.
Old Jun 11, 2006 | 01:13 PM
Default Re: 2 step....or 3 step (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">
to disable, just depress the clutch.</TD></TR></TABLE>
oooic my bad
Old Jun 11, 2006 | 04:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">i think he was asking about enabling and disabling... not changing.
yes....so only hondata has a switch like that?
i think ill go with msd's ignition cut out instead of the fuel cutout unless anyone can give me a reason not to..
Old Jun 11, 2006 | 04:54 PM
go with msd, it uses that modual, but it uses pills instead of switch, so u would just have to change the rpm pills to wat u want, i like the hondata one cause its convenient. But i like that msd ignition one too
Old Jun 11, 2006 | 05:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">go with msd, it uses that modual, but it uses pills instead of switch, so u would just have to change the rpm pills to wat u want, i like the hondata one cause its convenient. But i like that msd ignition one too</TD></TR></TABLE>
i know the msd has pills,, but does it have a clutch switch? how exactly does the msd one work?
but also whats the differences in a fuel cutoff and ignition cutoff 2 step?
do the msd modules come with pills.. it doesnt say and i didnt see a place to order them seperately.
Old Jun 11, 2006 | 05:34 PM
nerdsports's Avatar
i think ill go with msd's ignition cut out instead of the fuel cutout unless anyone can give me a reason not to..</TD></TR></TABLE>
well, i believe crome has the option to use your a/c button as a switch to enable/disable full throttle launch.
msd uses pills or you can buy an rpm selector. it's a rotary **** that lets you change the rpm by just turning the ****. i believe theyre sold in different ranges.
and yes, pills are sold seperately.
do the msd modules come with pills.. it doesnt say and i didnt see a place to order them seperately.</TD></TR></TABLE>
if you look at a wiring diagram for the 2step you can set the switch to whatever you want. you can put an actual switch or a misc button in your car (defroster, a/c, w/e) or clutch switch.
and ignition cutoff obviously cuts spark but still supplies fuel...
fuel cutoff cuts fuel (obvious again)... what i noticed with uberdata/crome is that my wideband displays LEAN when its bouncing off the preset cutoff rpm. cant say thats a great thing if you're building a few psi while its displaying LEAN.
Old Jun 11, 2006 | 05:41 PM
damn its hard deciding on all of this stuff. msd ignition 2 step or hondata/crome/etc. fuel cut 2 step??
hmm which one sounds cooler? lol
Old Jun 11, 2006 | 05:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">well, i believe crome has the option to use your a/c button as a switch to enable/disable full throttle launch.</TD></TR></TABLE>
so as soon as you launch you have to hit the a/c button? isnt that kind hard when your hand has to be on the ebrake for preloading the clutch then has to be back on the shifter?
and yes, pills are sold seperately.</TD></TR></TABLE>
yes i seen those...but would you have to get two of the rpm selectors for a 2 step?
Old Jun 11, 2006 | 06:08 PM
nerdsports's Avatar
i think this is the best way to explain it to you...
Old Jun 11, 2006 | 08:03 PM
Tactic$'s Avatar
^Bingo.
