Turbo oil drain help
Heres the turbo clocked towards the block with a 45 degree fitting
here's the pic with the turbo not clocked
The 45degree fitting is real close to the oil pan and if i put another fitting on the oil pan i dont think there is room to put a hose on. Before i put the fitting on the oil pan do u think i should run a 90 degree fitting on the turbo drain flange? is the 90 degree fitting safe as far as the oil flow goes? Any other suggestions? Im using a lovefab sst manifold.
Thanks in advance
Thanks in advance
Re: Turbo oil drain help (ki11a8ee)
I ditched the fitting and just went with a big and thick rubber hose made for fuel. It will allow better movement so you can place the oil pan bung as high as possible.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki11a8ee »</TD></TR><TR><TD CLASS="quote">Im using a lovefab sst manifold. </TD></TR></TABLE>
dithc that manifold or fix your motor mounts because that turbo is sitting way too low.
doesn't look to me like you'll be able to drain it much.
Re: Turbo oil drain help (ILLICON5000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILLICON5000 »</TD></TR><TR><TD CLASS="quote">dithc that manifold or fix your motor mounts because that turbo is sitting way too low.
doesn't look to me like you'll be able to drain it much.</TD></TR></TABLE>
motor mounts have nothing to do with the turbo.
Ditch the AN fittings and use some barbed fittings from home depot and some fuel line... Will give you more room.
I hate my AN fittings.. The line is so short and the damn thing leaks..
BEEYOND
09-02-2004 01:08 PM
