Boost....then no boost.....??
Old Jun 11, 2006 | 02:49 PM
SlowPokeEg's Avatar
Mike Jones
Default Boost....then no boost.....??
Ok, to start. D16z6 with HKS kit, (t25 w/internal gate)
W/G spring is giving me about 9.5-10psi, so naturally i bought a MBC. I actually bought a used Turbo XS Dual Stage. Hooked the first stage up about a month and a half ago and everything was fine. Once i hooked up the dual stage it seemed as if the first stage wasnt boosting as high as first installed but OK. So second stage added boost to first stage. Wonderful.
Well lately, i've only been spiking at about 10 psi, low boost and high. Also, my valvetrain is getting louder and i'm hearing kind of like an "exhaust/leaking air" type noise coming from around where i have my MBC mounted (In front of motor, in front of Cyl. 1). So i checked all my hoses and couplers today and sure enough one coupler was a little loose. Fixed it....test drive.....10psi still. Then, on the way home, the "exhaust" noise added a slight whistle to it.
I gotta borrow a compression tester before i can say if something internal is gone. Not sure if my valvetrain has ANYTHING to do with me being able to build boost. Could it be a defective MBC and i got suckered into buying a broke one?! I'm so confused
HELP! Sorry so long also....
dragsol
May 20, 2008 08:51 PM
agturbo
May 31, 2005 02:29 PM
pip9
Oct 7, 2004 02:46 PM
Sassafrass
Mar 17, 2004 12:38 PM
