Can a block extension be removed?
Old Jun 14, 2006 | 07:07 PM
totalimpact's Avatar
Default Can a block extension be removed?
I have a chance to get a B18 block with Darton sleeves and a 3/4" aluminum deck extension. I dont really want the extension because I already have money in some stock length rods.
Can the extension be removed and the sleeves just be milled down level to the original block height?
crappy pics:
Modified by totalimpact at 1:54 AM 6/18/2006
Old Jun 14, 2006 | 07:08 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Can a block extension be removed? (totalimpact)
stick with the deckplate and get longer rods...
Old Jun 14, 2006 | 07:13 PM
Default Re: Can a block extension be removed? (wantboost)
I'm poor- but ya, would love to keep it.
Old Jun 14, 2006 | 07:14 PM
VTcivicHB's Avatar
Wow, i had no idea that you could do that! I take it that you have some better torque with the longer stroke? how much does it cost to do someting like that and are there clearance issues under the hood at all?
MidShipCivic's Avatar
Thats actually a great thing you have there, but he'd have to have rods made for that .
wantboost's Avatar
Who is Mr Robot?
****, ill buy it
Old Jun 14, 2006 | 07:23 PM
hotimportcrx's Avatar
Default Re: (MidShipCivic)
lol nice block....jsut get the rods made....as far as milling it down to regular block height i think it would turn into a mess and is just not worth the aggravation...personally i never seen anyone do that before but the block looks good...just wait until you get the money to finish it right......youll be happy in the end but it sucks you have to wait to assemble your block.
Old Jun 14, 2006 | 07:32 PM
Default Re: (hotimportcrx)
Who wants to give me $300 for my low mile Eagle rods?
Old Jun 14, 2006 | 07:33 PM
wantboost - are you running a deck plate? Does it run on stock fuel maps?
Old Jun 14, 2006 | 07:34 PM
wantboost's Avatar
Who is Mr Robot?
im not running a deckplate... yet. and no built motor will run on stock fuel maps... just gimme the block
Old Jun 14, 2006 | 07:43 PM
95GSRTT
Guest
Posts: n/a
so how much longer do we have to stay tuned for you to actually be done with your build?
Old Jun 14, 2006 | 07:45 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Can a block extension be removed? (95GSRTT)
8200 dollars until the shell is ready to be reassembled. all the parts are sitting in the garage
Old Jun 14, 2006 | 08:39 PM
95GSRTT
Guest
Posts: n/a
better be worth the wait
Old Jun 14, 2006 | 09:18 PM
wantboost's Avatar
Who is Mr Robot?
it is... things have changed... power levels are slightly increased () hehehe
Old Jun 15, 2006 | 03:18 PM
Anybody want to buy my GSR Block and Eagle rods - please finance this new toy.
The block just has some wear on it, needs to go to 81.5mm, and has been clearanced for LS crank. I also have a freshly micropolished GSR crank, and 81mm CP Pistons.
Old Jun 15, 2006 | 04:22 PM
96 GSR-T's Avatar
I have no deck left on my block, I have never seen this before and I asked myself if this was possible.... how much do they charge to install this deck extension? My pistons are .016 out of the deck now And i would hate to trash a sleeved block cause it cant be surfaced anymore.
Old Jun 15, 2006 | 04:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">it is... things have changed... power levels are slightly increased () hehehe</TD></TR></TABLE>
A small change of his R/S will have little affect its not that much of a deal.
Old Jun 15, 2006 | 05:21 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Can a block extension be removed? (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">A small change of his R/S will have little affect its not that much of a deal.</TD></TR></TABLE>
i thought it was an ls block with a deckplate, not a gsr. bleh.
i just want the ability to run a big big big bore and a stupid long stroke
Old Jun 15, 2006 | 05:22 PM
Default Re: Can a block extension be removed? (96 GSR-T)
I dont think that would work for you, if you look closely at the pic you will notice the sleeves actually come up through the deck and are level with the top of the deck - so the deck does not sit on top of the sleeves, it sits around them.
The sleeve has to come all the way up to the block to be able to seal in that high pressure that we hope to maintain - otherwise this thing would have 2 head gaskets to blow
I am not sure about the price, i would imagine its somewhere around $500-1000 - call Benson Machine - he does it.
Old Jun 15, 2006 | 05:40 PM
96 GSR-T's Avatar
Yea i was planning on getting new sleeves, I am only an 81.5mm anyways...main reason is I would hate to scrap the block cause my current block cant be surfaced anymore, so a deck extension would be awesome, do an 84 or 85mm this time
Old Jun 15, 2006 | 05:59 PM
Muckman's Avatar
Moderator in Chief
What the hell do you do for a tbelt with a deck plate?
Old Jun 15, 2006 | 06:19 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Can a block extension be removed? (Muckman)
its just a standard belt.. find a longer one
Old Jun 15, 2006 | 07:05 PM
Muckman's Avatar
Moderator in Chief
Then it wouldn't be standard
Old Jun 15, 2006 | 07:30 PM
dornon13's Avatar
hot glue gun
Old Jun 15, 2006 | 07:33 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Then it wouldn't be standard </TD></TR></TABLE>
well i meant standard in that the tooth design/pattern whatever is common
