block sleeving
Old Jun 13, 2006 | 04:45 PM
teddy_dc2's Avatar
Default block sleeving
now's about the time to rebuild my motor, i wanted to start out buy sleeving it to 84.5mm with dart sleeves, where do they do a good job and a grand total $$ estimate, i keep hearing that these things leak, is that rear or common?
Old Jun 13, 2006 | 04:50 PM
komat's Avatar
Default Re: block sleeving (teddy_dc2)
http://www.laskeyracing.com/
pm earl for more info
Old Jun 13, 2006 | 04:51 PM
boostedcivicsir's Avatar
Mr. Badwrench
first why 84.5mm? that leaves you no room to go over if needed.
if it is done right, it wont leak.
my block was done at my local machine shop, 3 years ago, 84mm b16, and i have been beating the snot out of it over the last month. if it is done right you dont have anything to worry about.
i am goin with ERL this time.
Old Jun 13, 2006 | 04:57 PM
teddy_dc2's Avatar
i want to redo my set up this summer, want the most out of my motor.
Old Jun 13, 2006 | 04:58 PM
iBrandon's Avatar
Default Re: block sleeving (boostedcivicsir)
I would go 83mm or 84mm, like stated above. Just in case something went wrong and u can rehone and go bigger if needed...
Old Jun 13, 2006 | 05:11 PM
teddy_dc2's Avatar
laskey racing does quite some good building, is that botom end made to handle 700+ whp as stated? 84mm will be fine, are all sleeves same or some better quality.
dorado_mike
Oct 23, 2010 11:19 PM
Dave_Dc2
Jul 7, 2010 04:21 PM
igs22
Sep 15, 2007 07:48 AM
Red99CivicSi
Jun 18, 2003 12:52 PM
rig9896
Oct 3, 2002 04:00 PM
