Cylinder head chamber damage report
A rod went through my block (eagle) and my piston made contact with my head. How bad does this damage look? If there are any head porters in here, please include how expensive of a fix this looks to you.
Picture without flash:
Re: (oscarmayer)
honestly, i don't think it looks bad at all, i'd just take it to a good machine shop, have them inspect and probably change the valveseals and call it a day.
Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">send it to endyn and let them inspect it and fix it. I've seen head with cracks all the way through to the water ports caused by detonation they have fixed.</TD></TR></TABLE>
I rather send it to portflow or headgames
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">I rather send it to portflow or headgames</TD></TR></TABLE>
What? You don't wish to participate in the mystery that is Larry and his Swingers?
Oscar.... is every other post from you drag manifold this and Endyn that? Seriously...
To the poster... you've got a good chance that the valves are bent also... I'd get the head fluxed for cracks and if that looks good a complete once over should uncover anything else. That IN stamp in itself isn't going to hurt anything... its the possibility of cracks or bent things that will.
Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt »</TD></TR><TR><TD CLASS="quote">what the hell caused an eagle rod to go through the block. </TD></TR></TABLE>
Mad Vtec?
Sry... in wierd mood this morning.
Mad Vtec?
Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer »</TD></TR><TR><TD CLASS="quote">maybe because they do the best work?????</TD></TR></TABLE>
While they might do good/great work etc... they also have a fun history of blowing tons of smoke. There are tons of other options that won't promise you vaporware.
Still, get the head checked, a local machine shop can do the majority of diagnostics on it... if you want/need more work you can send it out then.
Re: (oscarmayer)
i still don't see many real examples of high hp cars sponsored or acknowledges by "endyn"
but I do see alot from headgames, ed's racing heads, and portflow...
Re: (igo4bmx)
but I do see alot from headgames, ed's racing heads, and portflow...</TD></TR></TABLE>
I have to agree on this.......
My head was chewed all to hell and it came out find with some welding and TLC, you will be ok
Re: (Zakar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zakar »</TD></TR><TR><TD CLASS="quote">i agree, it is totally usable. i saw the tread title and expected to see chunks... </TD></TR></TABLE>
Same here, it don't look to bad but I would get it checked out.
Re: (90blackcrx)
Heard back from some porters. They say it just needs a valve job... I imagine they'll clean up anything else that they deem needs fixing. Probably upgrade valves in the process as well... possibility of a bent valve(s)
89si-rex
15
01-18-2014 03:49 PM
SoCaLNaTIvE
04-24-2005 09:21 AM
