Piston ring filers
Old Jun 11, 2006 | 10:25 PM
zerovandez's Avatar
Default Piston ring filers
Anybody know where I can rent one? I went to autozone and they said that it's a purchase only item. Does anybody know where I can rent one? Or maybe someone in socal would be so kind enough to let me borrow one?
Old Jun 12, 2006 | 06:29 AM
JDogg's Avatar
Default Re: Piston ring filers (zerovandez)
use some files, or just buy one, they are cheap
Old Jun 12, 2006 | 01:39 PM
Redwidow's Avatar
Can you use a dremel? I think i might..
Old Jun 12, 2006 | 05:56 PM
zerovandez's Avatar
i dunno about a dremel. You'd have to have really steady hands for that. So no luck on any rentals or lenders?
Old Jun 12, 2006 | 06:07 PM
iBrandon's Avatar
Default Re: (zerovandez)
i use a dremal...just be very gentle and go very slowly...couple nicks and measure....couple nicks and measure...be sure ur doing it straight...then after ur done sand the edges smooth with 1000/1500 grit so u dont create hot spots on the edges that are keen... or buy a file grinder
Old Jun 12, 2006 | 07:03 PM
zerovandez's Avatar
I'll give a dremel a try. what speed recommendation do you advise?
Old Jun 12, 2006 | 09:24 PM
earl's Avatar
http://www.laskeyracing.com/shop/ringgap.htm
read down to the last paragraph
Old Jun 13, 2006 | 03:01 AM
ef92b's Avatar
Default Re: (earl)
thanks for the link earl
Old Jun 13, 2006 | 04:03 AM
2point2's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">http://www.laskeyracing.com/shop/ringgap.htm
read down to the last paragraph</TD></TR></TABLE>
http://www.laskeyracing.com/shop/techarticles.htm
Old Jun 13, 2006 | 07:30 AM
Redwidow's Avatar
Default Re: (2point2)
great info Earl What gap do you recomend for JE rings and 84mm bore...Also on the ring chart its hard to determin which ring is top and which is bottom , one has a dot which faces up and the other has nothing, a lil difference in color...I remeber my last JE rings tobe different...Thanks for the help...
Old Jun 13, 2006 | 07:46 AM
earl's Avatar
Default Re: (Redwidow)
Usually the upper ring is only 1mm thick and the second ring is 1.2 to 1.3mm thick. If that is your case, you could not put the middle ring into the upper ring land opening.
If you are doing a turbo motor, .018" upper and .020" middle gaps should work fine for you.
Old Jun 13, 2006 | 08:13 AM
Redwidow's Avatar
Default Re: (earl)
Thanks I'll check that out when I get home also a PM to you on another thread no one will respond on
Old Jun 13, 2006 | 08:29 AM
zerovandez's Avatar
Thanks for help guys!
Old Jun 13, 2006 | 08:52 AM
HybridKOOP's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Usually the upper ring is only 1mm thick and the second ring is 1.2 to 1.3mm thick. If that is your case, you could not put the middle ring into the upper ring land opening.
If you are doing a turbo motor, .018" upper and .020" middle gaps should work fine for you.</TD></TR></TABLE>
Always continuing to help out the HT community
BadDrivrGoodCar
Aug 3, 2016 02:08 PM
RACEPAK
Welding / Fabrication
18
Sep 9, 2010 04:54 AM
