Which Injectors To Get with DRAG kit? / Which walbro fuel pump, 190 or 255lph?
I was thinking a set of 310 CC injectors & a Walbro 190 LPH fuel pump (in-tank). This will be tuned on Hondata. Just trying to find the right combo so I dont dump to much fuel & loose out on my gas mileage. Will be on a daily. LMK.
Re: (Integra_RS)
if you're concerned about gas mileage....stop right now. Sell your turbo setup and get a dpfi 1.5L.
Definately get the 255 walbro and at least 440cc's.....310's will max out quick on even a small turbo. Depending on your setup you might wanna even go larger than 440's.
Gas mileage out of boost should be like normal, but in boost b/c of 12:1 air/fuel ratios its gunna drink gas.
Re: (zman)
Either fuel pump will suffice, hell the stock fuel pump should be fine for a stock motor, but the 310s are too small imo. Stock ones are 240. 2nd the motion for some used DSM 450s. I also would like to say forget about the drag kit and put together your own kit (used parts if possible) to get exactly what you want and save money, unless you are getting a good deal on the kit. You can save more money by going with an alternative ems (crome / pro, uberdata). The injector size doesn't dictate 'how much gas will be dumped,' your ECU does. Maybe with all this money you saved you can afford some gas to feed your ~100% more horsepower. good luck
i'm running a walbro 190lph with 550cc rc injectors and it runs great. i herd the walbro 255lph needs a fuel regulator and i didn't needed that because i wasn't aiming for any hp higher than 200whp. the 190lph with 550cc can handle up to 300whp on stock honda fuel lines.
Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">i'm running a walbro 190lph with 550cc rc injectors and it runs great. i herd the walbro 255lph needs a fuel regulator and i didn't needed that because i wasn't aiming for any hp higher than 200whp. the 190lph with 550cc can handle up to 300whp on stock honda fuel lines.</TD></TR></TABLE>
Where'd you hear this?
Re: Which Injectors To Get with DRAG kit? / Which walbro fuel pump, 190 or 255lph? (Integra_RS)
dsm 450cc's, resistor box, and walbro 255 hp.
Sometimes with those b&m adjustable fuel regulators (uses your stock regulator) the pressure of the walbro will cause it to malfunction. I've come across 2 set-ups that encountered this problem but then again I've worked with a few stock FPR's that worked just fine with the walbro hp pump. So in my opinion... it can be a hit or miss thing. I'm not a fan of the b&m fpr addition anyways though.
Re: Which Injectors To Get with DRAG kit? / Which walbro fuel pump, 190 or 255lph? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">dsm 450cc's, resistor box, and walbro 255 hp.
Sometimes with those b&m adjustable fuel regulators (uses your stock regulator) the pressure of the walbro will cause it to malfunction. I've come across 2 set-ups that encountered this problem but then again I've worked with a few stock FPR's that worked just fine with the walbro hp pump. So in my opinion... it can be a hit or miss thing. I'm not a fan of the b&m fpr addition anyways though.</TD></TR></TABLE>
I'm running a walbro and a B&M. My fuel pressure when up to 56, and i can only turn it down to 48psi.
Modifying the regulator will knock the pressure back down further
get a walbro 255lph fuel pump and at least 550cc injectors or some 450 dsms if you dont have the money but if you get the dsms member to take the resistor box too . but I wouldnt settle for a 190lph fuel pump because you know and I know you are going to turn that boost up more , so just make sure your fuel system is up to par just in case you get bored of a 7psi with a whopping 200 hp car lolz!
BroskiZach
04-24-2014 08:01 AM
bazoOKA_ TOoth
12
09-30-2010 02:45 PM
Davanca
06-22-2003 12:06 PM
